Water pump issues ...
Old 07-30-2013, 10:26 PM   #11
Hrdcor is currently offline
My Model: Shabah 210
My Engine: 5.7 bravo 3
Send Hrdcor:
Default Re: Water pump issues ...
Thanks guys ... Sounds like a good idea ... I found one online , a solid stainless steel one . I just need a pulley for it . Any idea where to get a pulley for it ???
  • Old 07-30-2013, 11:38 PM   #12
    Check HERE for the pulley.
    Just make sure you have the right serial number.
    That one might be the one you need , or might not. But you can do your own search , and at least get the part number if you want to look elsewhere for a better deal.
    Hrdcor likes this.
    Old 07-31-2013, 04:55 AM   #13
    Send Hrdcor:
    Where would I get the serial # for my part ???
    Old 07-31-2013, 04:59 AM   #14
    Sorry ,
    Need the Serial Number from the engine.
    Is your engine MPI or Carbed?
    Old 07-31-2013, 05:08 AM   #15
    Send Hrdcor:
    Sorry ,
    Carb.
    Old 07-31-2013, 05:17 AM   #16
    Need the serial number to be sure.
    Hrdcor (07-31-2013)
    Old 07-31-2013, 05:27 AM   #17
    Send Hrdcor:
    Kewl... Thanks , I'll figure it out from here I'm sure ...
    Old 08-13-2013, 10:52 PM   #18
    Send Hrdcor:
    Well my sea water pump cracked apart in the rear ,,, it's plastic ofcorse ... Any idea where I get the engine # to order the replacement parts ?
    Old 08-13-2013, 11:05 PM   #19
    See if you have the drive # on the outer transom mount. That should do the trick.
    Otherwise , it should be on a valve cover , carb cover , or maybe the right rear(port side) of the engine on the bell housing.
    Old 08-13-2013, 11:08 PM   #20
    Is your 5.7 injected or carbed?
    7.4l water pump edward cossey Projects 6 02-05-2015 02:53 PM
    Electrical issues, sink water pump V-side-down Original Mariah Talk 1 07-18-2012 01:57 AM
    Raw Water Pump Lee Volvo Penta 3 10-19-2010 03:56 AM
    Fuel pump issues. jetscat7 Original Mariah Talk 4 05-09-2010 06:40 PM
    water and sewage issues tim davantiz275 intrbl Original Mariah Talk 0 07-14-2008 02:10 PM
    There are 294 users
