Problems with getting newly purchased boat operational.
Old 04-10-2013, 11:47 PM   #1
TomFasig is currently offline
My Model: 201 Talari
My Engine: 5.7L Alpha One Gen II
Send TomFasig:
Default Problems with getting newly purchased boat operational.
I presently have two questions about a 1996 Mariah Talari 201 w/Mercruiser 5.7L w/Alpha One. First question is: Did this boat originally come with a belt driven water pump or just the standard water pump that comes on all 5.7L including automotive? Also, I got the engine running, but it will not shut off with the key. What could be wrong. Sorry to be so dumb, but I haven't had a boat in several years. I'm sure that it is probably something simple, but I can't figure it out. I don't have a wiring schematic, but I guess I may need to get one. Do you know if there are any wiring schematics available for this boat? Any help will be greatly appreciated. Thanks, Tom
  • Old 04-11-2013, 12:02 AM   #2
    Default Re: Problems with getting newly purchased boat operational.
    Tom here is the wiring diag for the starting system.
    Click on Merc Manuals on the main forum page(bottom of maint & repair section) and then go to the 5.0 & 5.7 manual.
    Click on "Electrical Systems" page 5
    The manual also goes into further detail on your cooling system , but yes the "seawater pump" as they are called was available on your engine package.
    Old 04-11-2013, 12:12 AM   #3
    Send TomFasig:
    Thanks Colorado, for the reply. I've looked all over this site and haven't been able to access any manuals. I'm sure I'm just not doing something right. My boat does not have one of those pumps and I saw on YouTube that, that was an area that needed to be addressed, periodically, to change the impellor, but when I went looking for it, I discovered that it wasn't on my boat. Is that something I should worry about. Thanks, Tom
    Old 04-11-2013, 12:20 AM   #4
    Nope , nothing wrong with your boat. You just don't have that system on your drive package. Your impeller is in the outdrive itself. And yes , if you don't know when it was last replaced........replace it.
    To be completely honest , I can't tell you the diff in the two , but one of the guys will educate us both I bet
    At the top of the MOC page click on "forum"
    Go down the page til you get to "Maintenance and Repairs"
    Just below the last entry of "Yamaha , OMC , and other motors" you'll see the link for the mercruiser manuals.
    Old 04-11-2013, 12:22 AM   #5
    Send TomFasig:
    Got it. Thanks. I'm still learning.
    Old 04-11-2013, 12:34 AM   #6
    No prob Tom. That's why we're here
    Old 04-11-2013, 12:39 AM   #7
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    Just curious....how are you shutting it off if the key doesn't work? As far as where to look....starter solenoid/coil/distributor area. Something is wired wrong.
    Old 04-11-2013, 12:45 AM   #8
    csterner's Avatar
    csterner is currently offline
    My Model: Z275ST Shabah
    My Engine: 6.2L Bravo III
    Gallery Images: 9
    Send csterner:
    Welcome aboard Tom! I am no expert by any stretch, but I have changed a few impellers before. When you started the engine, did you put ear muffs on the bottom of the outdrive? Did water come back out with the exhaust? You said that you do not have a belt driven water pump so I am guessing your impeller would be located in the "foot" or bottom part of the outdrive. If water did circulate back out of the engine then that means your impeller is functioning, but if it has been sitting awhile, I would change it. The rubber fins will get brittle and you don't want that falling apart in there.
    2001 Shabah Z275 ST
    6.2L Merc with Bravo III
    Old 04-11-2013, 01:03 AM   #9
    Send TomFasig:
    Husker_Fan, I debated on how to shut it off and I finally just pinched the fuel line shut and let it run out of gas. Csterner, I did use the ear muffs and yes, water did come out of the prop. I know that I have to change the exhuast bellow and I do intend to change the impellor. Just another question: How do you know if the gimbel ring (bearing) is good or bad?
    Old 04-11-2013, 04:10 AM   #10
    Tom: If you have a look in this same section under the heading "General Maintenance" you will find 6 or 7 'stickys' that give you instructions on how to troubleshoot your starting system, your shift system, gimbal bearing etc. Keep us informed on how things go....i've never had a motor that didn't wanna shut off on me...
    Purchased a '93 212 Shabah this past June Saucy1 Introductions 5 02-04-2013 08:30 PM
    First Ski Boat Just Purchased mariahsx20 Introductions 1 07-22-2012 04:14 AM
    New member just purchased PCap Introductions 16 07-21-2012 03:57 AM
    New member: problems cold starting boat steveog17 Original Mariah Talk 2 09-04-2009 02:04 AM
    New member w/ boat problems! dmg5606 Original Mariah Talk 3 08-25-2008 04:50 PM
    There are 337 users
