Outdrive not going down or up
Old 07-01-2011, 02:37 AM   #1
bobcatdad48 is currently offline
My Model: Z220 talari
My Engine: 5.7 Bravo 3
Send bobcatdad48:
Default Outdrive not going down or up
I have a bravo 3 Mercruiser. When trying to lower the outdrive from the throttle, I get a clicking sound. Any thoughts?
  • Old 07-02-2011, 12:27 AM   #2
    csterner's Avatar
    csterner is currently offline
    My Model: Z275ST Shabah
    My Engine: 6.2L Bravo III
    Gallery Images: 9
    Send csterner:
    Default Re: Outdrive not going down or up
    I would check your 20 amp fuse next to the trim solenoids, try jumping across your solenoid to see if it is a bad solenoid, check and clean all connections.( I have had several solenoids that looked like they were bad, but after cleaning the connections, they worked like a charm. Connections should be bright and shiny.) Also, make sure your battery is fully charged.
    2001 Shabah Z275 ST
    6.2L Merc with Bravo III
    Thank you csterner for this useful post!
    pattybertolucci (09-04-2019)
    Old 07-02-2011, 12:14 PM   #3
    Send bobcatdad48:
    I actually did that after doing some research online after posting this and you are right. After cleaning all connectors, it worked. Thanks for the reply.
    Old 07-02-2011, 01:13 PM   #4
    csterner's Avatar
    Gallery Images: 9
    Send csterner:
    Glad you got her going!
    2001 Shabah Z275 ST
    Old 09-04-2019, 04:14 AM   #5
    pattybertolucci is currently offline
    My Model: 202 bow rider
    My Engine: 5.0 merc
    Send pattybertolucci:
    I’ll clean the connectors
    Raising the outdrive? GageCreasy Original Mariah Talk 3 07-02-2011 12:22 AM
    Alpha gen II outdrive cwdog2001 Mercury MerCruiser 5 05-15-2011 11:40 PM
    Where can I find an outdrive? jasfiveo Original Mariah Talk 3 07-15-2010 09:17 PM
    Outdrive shot....Help jasfiveo Original Mariah Talk 5 06-21-2010 05:44 PM
    Outdrive 96blackmariah Original Mariah Talk 6 06-22-2009 04:11 PM
    There are 254 users
