Anyone know what this is?
Old 05-15-2011, 09:43 PM   #1
Purple_Shabah's Avatar
Purple_Shabah is currently offline
My Model: Shabah 182
My Engine: 4.3 Apha
Gallery Images: 19
Send Purple_Shabah:
Default Anyone know what this is?
We got Shabah out of hibernation FINALLY! She started up pretty easily, the buzzer/beeper comes on as normal when you turn the key, but once the engine is started, it changes tone a little bit, and stays on even after the engine is running. Anyone know what this might be?
It's a 2000 4.3 Mercruiser. Thanks for your helpe!
Time flies when you're having rum.
  • Old 05-15-2011, 11:14 PM   #2
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    Default Re: Anyone know what this is?
    It may be changing tone just from voltage difference from the engine on vs. engine off. The alarm though is likely from either of the 3reasons for the alarm, Engine heat(obviously not overheating, but could be a bad sensor) Engine Oil Pressure or sensor, or the most likely culprit the outdrive fluid level. I would check that first.
    Hope this helps, Im sure you will find it.
    Zack
    1994 Z212 Shabah
    Old 05-15-2011, 11:40 PM   #3
    My Engine: 4.3 Apha
    Gallery Images: 19
    Send Purple_Shabah:
    Thanks Zack, I did notice that the drive fluid level bottle was low, I'm going to top that off and see if that fixes it. When I put it away last fall it was fine, this just came about by sitting over the winter? weird.
    Kevin
    Old 05-16-2011, 01:26 AM   #4
    What he said
    I would monitor your outdrive fluid level closely for the next month or two just in case there is a leak somewhere.
    Old 05-24-2011, 05:02 PM   #5
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Did you have the outdrive serviced when it was winterized? If they changed the gear lube, chances are there were some voids that got filled in from oil in the reservoir, which is why that's now low.
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 05-24-2011, 05:12 PM   #6
    My Engine: 4.3 Apha
    Gallery Images: 19
    Send Purple_Shabah:
    I winterized it myself, I had a 3.0 Mercruiser before and always winterized it myself, but that engine didn't have a drive fluid reseviror. I topped it off and the alarm has went off so all is good.
    Old 06-08-2011, 08:41 PM   #7
    Shabah 198SE's Avatar
    Shabah 198SE is currently offline
    My Model: Shabah 198SE
    My Engine: 5.7L Alpha
    Send Shabah 198SE:
    Purple_Shabah,
    When I refill my outdrive, I have someone watch the reservoir level while I am filling the drive (after I have installed the upper plug when the gear lube reaches that point). When the reservoir level comes close to the cold fill mark, I install the lower plug in the outdrive. Then I top up the reservoir slightly. Works great. You can do it on your own, but your need to keep checking the reservoir level once you have insalled the top plug.
    Shabah 198SE
    Thank you Shabah 198SE for this useful post!
    mikeyt (06-09-2011)
    There are 375 users
