Compression Check
Old 06-12-2009, 06:14 PM   #1
Colin Logie is currently offline
My Model: 1997 242 Talari 7.4 L Bravo 1
Send Colin Logie:
Default Compression Check
I just got a call from the mechanic, he has done a compression check on my 7.4L MPI with 550 hrs on it. the readings varied from 100 to 110 psi. Should I be looking at a new power plant ? Can I get the season out of this one ?
  • Old 06-16-2009, 02:21 PM   #2
    AirNavy's Avatar
    AirNavy is currently offline
    My Model: Z215 Talari
    My Engine: 5.7L Alpha One
    Send AirNavy:
    Default Re: Compression Check
    It is low (normal is around 150 psi), but at least there's not a big split between any of them. That points to normal wear as opposed to specific damage. Sounds like it may be about rebuild time.
    Mickey
    AEC (AW) U.S. Navy
    Old 06-16-2009, 03:20 PM   #3
    Send 300sflyer:
    That seems like fairly low hours generally speaking for it to be worn out. Other than the low compression, are there any other problems with it? Does it run ok?
    Old 06-16-2009, 09:45 PM   #4
    Send Colin Logie:
    Runs fine, does'nt use any oil, I would'nt have known the compression was out if the shop had'nt told me.
    Old 06-16-2009, 09:50 PM   #5
    Send 300sflyer:
    Hmmmm....
    I wonder if the gauge the shop was using was accurate? If it were me, I'd get a second opinion, or check it yourself. Its not hard to do.
    Old 06-16-2009, 10:49 PM   #6
    Send Colin Logie:
    Thanks, good advice, I'll do that before I open my wallet.
    Old 06-16-2009, 11:32 PM   #7
    Send 300sflyer:
    Reminds me of that old saying... "If if aint broke... don't fix it".
    Think I found prop want to check 95Z212 Prop Talk 6 09-08-2008 02:49 PM
    First Time Out / Check your hoses! Z275 Original Mariah Talk 0 04-29-2008 05:05 PM
    check out this engine cover 180diablo Chit Chat/Off-Topic 17 04-04-2008 08:43 PM
    Really?!? Check out this Mariah's Decal Job ShabahZ280 Chit Chat/Off-Topic 3 01-29-2008 07:51 PM
    check out this forecast ! 180diablo Chit Chat/Off-Topic 5 10-05-2007 08:43 PM
    There are 331 users
