Boat Warranty
Old 02-26-2009, 02:21 AM   #1
twospeed46's Avatar
twospeed46 is currently offline
My Model: 2002 250 Cuddy cabin 5.0L EFI Alpha 1 25 ft
Gallery Images: 10
Send twospeed46:
Post Boat Warranty
I Recently purchased a 2002 Cuddy Cabin I have been looking around for a maintenance contract that covers the 5.0L mercuriser which has 73 hrs on meter ,I've been quoted $1,295.00 a yr, it seems high to me ,would like some opions
  • Old 02-26-2009, 03:07 PM   #2
    Default Re: Boat Warranty
    I've never really looked into any marine maintenance contracts, to be honest I've never had that many issues with any Mercruiser motor that would justify spending $1295 a year.
    I had a 4.3L in my old Sea Ray 180, the only trouble it ever gave me in 10 years was the impeller every 3-4 years, the bellows needed replacement, and the carb needed a tune-up once. Other than that, no problems. With the 7.4L MPI, the only issues I've had were once again, the impeller, a bad gimbal bearing, and a gear lube reservoir sensor going bad. The impeller and the gear lube reservoir were around $200-300 to get fixed at the local Mercruiser service center. The gimbal bearing was a little more expensive.
    Now I can certainly understand the peace of mind of a service contract, and if that's what you're looking for, then maybe it's best for you. It is a comforting feeling. However I'm a slight bit mechanically inclined, and don't mind doing some work myself. If it's beyond my means, I'll take it in for service. I'm a little intimidated by winterizing still, so I leave that to the pros. If that's not done properly, it could be a $5k fix. But, like I said, I've never really had any issues in the 16 years I've owned Mercruiser products that warranted such a serious amount of money for service. I've got an insurance policy on the boat should something catastrophic go wrong, I believe the engine is covered under that.
    $1295 buys a lot of gas for the boat!!
    Old 02-26-2009, 11:53 PM   #3
    twospeed46's Avatar
    Gallery Images: 10
    Send twospeed46:
    Post Re: Boat Warranty
    thanks everyone for your input about boat warranty,something to think about,only concern is I have no idea how long the boat set up without run???
    Warranty Claims dudders Sea Fox - Mariah Talk 10 10-08-2007 06:22 PM
    There are 359 users
