'94 Talari 200z overheating?
Old 07-01-2023, 07:54 PM   #1
wickhoi is currently offline
My Model: Talari
My Engine: 5.0L bravo
Send wickhoi:
Default '94 Talari 200z overheating?
I have a 94 talari 200z with the 5.0 mercruiser. I just started it for the first time this year. Let it come to temp. Did not see any water flowing out the exhaust. (i had muffs on it). Temp. went up to just above 175 and the alarm sounded. I definitley have enough gear oil.There was no water leaking in the engine compartment. How do I tell if it's my impellar or the thermostat? Any other things I should do or check? I'm a very amateur mechanic so please tailor any answers as such. Thanks!!
  • Old 07-07-2023, 03:48 PM   #2
    GregT is currently offline
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    Default Re: '94 Talari 200z overheating?
    You should have had water flowing with muffs, so there may be a blockage somewhere. start with the water flow path first, take a hose off the waterpump and see if you get flow there, then go to the next location because if you put water in then you should get water out.
    overheating , thermostat , water pump
    My '94 Talari 200Z is listing... wrong prop? wickhoi Prop Talk 4 05-09-2016 08:14 PM
    '94 Talari 200Z replacement prop wickhoi Prop Talk 0 04-17-2016 01:14 PM
    overheating mikec Original Mariah Talk 0 07-10-2011 11:58 PM
    496 HO overheating trathbun2 Original Mariah Talk 10 07-08-2011 04:42 PM
    Overheating problem update karmann Original Mariah Talk 2 07-07-2009 12:09 PM
    There are 285 users
