What cam???
Old 06-17-2016, 08:47 PM   #11
My Model: Z276
Send Brian Belcher:
Default Re: What cam???
Dude. I'd leave it flat. I was just showing off I knew about rollers !
New lifters will come with the tie bars and you wouldn't need the spider. The spider holds the alignment of the lifters. And your right, you'd have to change dizzy gear. $60 for stock. Something know one mentions is a thorenson bearing for can walk. A cam button doesn't last long. (As I've found out!).
I've NEVER worked nor not built a marine motor but I'm doing a ton of research on them. Totally different beast from all my off road machines. I had every intention of taking one of my 640hp 6.2 LS motors I've built and putting it in. I've learned they won't live long not will my Bravo III outdrive. I'm taking my stock stuff and going to do the usual port matching, radiusing, chamfering of oil ports, and ARPs all around. Point being, stay stock ! Back pressure is your friend on marine. Love seperation is VERY VERY important.
I sure do like working on my boat cause for the first time, the entire family benefits
  • Old 06-18-2016, 01:31 AM   #12
    Bigred89 is currently offline
    My Year: 1991
    My Model: MX19
    My Engine: Merc 4.3l / Alphaone
    Send Bigred89:
    Oh I am going with the flat!!!lol just hate doing the cam break-in. I rebuilt the 350 tbi in my truck last summer and went with the flat, RV cam. An LS engine wouldn't last? Why is that? They are bulletproof in the trucks. 600+ hp in a boat would be insane!!!
    Old 06-18-2016, 03:33 AM   #13
    My Model: Z276
    Send Brian Belcher:
    Don't let me mislead you in thinking I have hands on experience. Just repeating everything I've researched.
    I was under the impression that the Mercruiser 454 was JUST a rebadged, street engine. Not so. The spinning gear is all specially formulated parts. The piston have a very low silica ratio for possible water contact. The rods are heavier duty than anything GM ever offered. Sodium filled exhaust valves came from Mercury. Our engines are much beefier than their street versions.
    Now, this is my opinion so take it as you wish;
    The LS is the "smartest" engine ever built by any manufacturer. The cathedral intake runners, the windows on the main crank caps. The simple but major problem solving "steam pipe". The six bolt caps to the powder metal con rods. All smart and all stronger than anything, anyone, has ever made before.
    But
    The block is vulnerable without that awful ugly oil pan. The pan is actually structural and if you you replace it with a pretty gold anodized Moroso, the block WILL contort and twist, taking the main bearings with it. Slow death but it still will cause uneven wear across the bearing. To save weight, the bell housing of the 4L60 and 80 are figured into structure and it is engineered that way.
    Here's a huge issue for me and not doing the LS. The programming running these beast are looking and struggling to keep the stoic...stoic. The OBD-II and the evil, CAN bus are ALWAYS struggling for that 195-205 water temp. Too cool, it leans it out. Too hot, richens it. So, the O2s can't get hot enough and the flip flopping between open loop and closed looped etc etc etc.
    hands down, I believe (opinion again) the LS is the only way to go in a consistent and semi-controllable environ like the street. But when you start throwing constant water temp changes, crazy humity changes (MAP sensor) and I can see a programming nightmare.
    Oneday, I'm going to look for folks who've made the swap. I'd like to see how they overcame the issues I named.
    One last thing I just remembered.
    All of the motors I've built over 500hp, all had to run on V-MS109. It's $750 a barrel (54gal?). That's around $13 a gallon. I could back some timing out on the cam gears but that's a lot of tq thrown away.
    I believe Mercury did their homework on these motors. As bad as I want to hop it up just a little, I'll heed the warnings from those that scream "Leave it alone!"
    if you take anything from what I've said, take this one thing. Get the biggest push rods you can ! I know a fella running a twin turbo 4.3 and he was constantly bending the 3/8 rods. He was running a very mild cam and low CR due to the turbos. After he bent the second set, he brought to me (us) and I measured with my adjustable and got the rockers centered on the valve stems. The third set of rods were the Comp Cam 3/8 chromos and he bent them !
    Comp "comped" him and he went to the 7/16". That was 2 yrs ago. We would have gone with 1/2" but the guides were too small.
    Old 06-18-2016, 03:39 AM   #14
    My Year: 1991
    My Model: MX19
    Send Bigred89:
    IF a guy were to swap an LS into a boat, I would forego the EFI and just get a 4 barrel intake made for the LS....would simplify things immensely.
    Old 06-18-2016, 05:19 AM   #15
    My Model: Z276
    Send Brian Belcher:
    I agree on the simplifying but those electronics are the magic of the LS. Really, any modern engine. I hated OBD systems when they first came out but I forced myself to learn the 5 major sensors, counting the IAC as a sensor, and not including any speed density,and haven't looked back since.
    BTW. Do you have any clue how you could mount an O2 sensor in the exhaust ? I could bung it up so it stayed dry but you'd think the steam would dilute the exhaust mixture.
    I'm going to put a bone stock 1997ish Mercury MPI. I have access to a complete system. I wonder if it's speed density...
    Was going to do a complete FAST 2.0 set up but everyone has talked me out of it. Seems the Bravo III is running at the ragged edge with 400hp.
    My hole shots are non existent. And my top end, right now, is in the 35mph range.
    There are 300 users
