What cam???
Ok, so I got a 91' mx19 as a project. 4.3l merc Engine is in pieces. With the boat I got reconditioned heads, crank, and block. Now the block is a casting number 1986, is bored .060" over. But in all the boxes I got, there is no cam or lifters. Just pushrods. So I'm trying to find out if this would have been a flat tappet or roller. I just put a GM crate 4.3 in a friends 91' Chevy truck and the original mill with over 350k miles was a roller. But it seem Merc was all over the place in using both. Anyone have a clue what I should go with? Hoping it's a roller as to avoid the flat tappet cam break in!!!!! Thanks
Re: What cam???
Anybody have any input?????
Re: What cam???
You might get somewhere on mercruiserparts.com and search a serial or model or year. The diagrams might help you out. I dont personally get into these engines to know about the valve-train.
Re: What cam???
Re: What cam???
What I've found says roller. What's the push rod length ?
Flat tappet use 7.8" rods whereas rollers use. 7.3". |
Re: What cam???
Re: What cam???
I didn't catch the 1986 the first time around. Best I can find, 1987 is when they went roller.
I wonder why the 86 motor in a 91 boat ? But there ain't nothing wrong with flat tappers. Just have to add zinc at every oil change unless you can find SJ rated motor oil. Last time I looked, it was up to SN on the code. I think you could use Valvoline VR1 20-50 and be golden. |
Re: What cam???
Re: What cam???
You going to convert to roller ? You've got to buy a cam and I'm ass-u-meing that you have no lifters. Change the dizzy gear and new push rods and you'll have a roller motor with no worries of cupping.
Just saying... |
Re: What cam???
In addition to needing the things you mentioned, I would also need the lifter guide plates, lifter hold down spider, and I think it takes a different cam gear for the timing chain. I don't think my block has the bosses for the lifter hold down plate. I'll have to go out and check, I just picked up the block from the machine shop.
| All times are GMT. The time now is 05:42 PM. |
