New 1996 Mariah Shabah 180 owner
Introductions
Old 06-28-2014, 12:25 AM   #1
Larrypiper is currently offline
My Model: Sabah 180
My Engine: Mercuruiser alpha one
Send Larrypiper:
Default New 1996 Mariah Shabah 180 owner
Looking forward to getting in water! Just noticed that the motor will lower but not raise back up? Would love an owners manual!
  • Old 06-28-2014, 12:31 AM   #2
    Default Re: New 1996 Mariah Shabah 180 owner
    Welcome to MOC Larry! Here
    is some info on "Owners Manuals".
    As for your Trim issues , take a look at THIS thread.
    Are you using the trailer button to raise the drive?
    Old 06-28-2014, 02:39 AM   #3
    Jimh23 is currently offline
    My Model: 180 Diablo
    My Engine: 3.0L Alpha I
    Gallery Images: 4
    Send Jimh23:
    Just had the same type of problem. The lower unit would be raised by the trailer switch so those mechanics were working. My mechanic corrected the problem by cleaning the trim switch. I do not know what he used but it did not take him very long.
    Old 06-28-2014, 01:56 PM   #4
    My Model: Sabah 180
    Send Larrypiper:
    Thanks guys! Unfortunately the only switch I can find is on the throttle. Where is the trailer switch? At this point the motor is all the way down which would make it difficult to haul to a mechanic.
    Old 06-28-2014, 02:51 PM   #5
    Gallery Images: 4
    Send Jimh23:
    Both the trim and trailer switch are on the throttle handle. The trailer switch is the square button just below the trim switch. To fully raise the out drive, press the button until you hear the pump stop working.
    The Following 2 Users Say Thank You to Jimh23 For This Useful Post:
    Bosgarage57 (06-30-2014), Larrypiper (06-28-2014)
    Old 06-30-2014, 02:25 PM   #6
    Bosgarage57 is currently offline
    My Model: Barchetta
    My Engine: 4.3 Merc
    Send Bosgarage57:
    Jimh thank you, I too couldn't find the trailer trim switch....very smart Mariah.....tricky Our trim isn't going all the way up either, so we are going to look at the trim switch/ clean it and readjust it.
    Old 06-30-2014, 09:43 PM   #7
    There is a difference between the trim switch and the trailer switch. The trim switch only offers limited up movement (which is why its a 'trim' switch) and full down movement. The trailer switch is used to fully raise the outdrive. Most boat manufacturers arrange them this way so its not Mariah being 'tricky'. Note also that some boats have a trailer switch on the transom too that makes things easier when you're on land. They are easy to add IF you are capable of a little electrical work.
    Old 06-30-2014, 09:56 PM   #8
    My Model: Barchetta
    My Engine: 4.3 Merc
    Send Bosgarage57:
    thanks, so I guess my question is......how far up does it go with "trim up" being used. I'll try to get a pic of mine full trim up and post it for you to inspect.
    Old 07-01-2014, 10:36 PM   #9
    The 'up' trim likely only moves about 25-30 degrees at most. Its designed that way as a safety feature.
    hydrolics
    Proud owner of a near new 1996 Mariah Shabah 210 efo Introductions 25 12-17-2018 11:44 PM
    New Mariah Owner! - 1996 Mariah 210 Shabah Superstang Introductions 8 03-23-2013 05:00 PM
    1996 Mariah Shabah mustang67gt1 Introductions 4 09-23-2012 03:02 PM
    New owner of 1996 Z210 Shabah menastydude Introductions 2 01-29-2012 02:12 AM
    1996 Z210 Shabah new owner baker721 Introductions 7 06-21-2011 12:26 AM
    There are 242 users
