1996 Z210 Shabah new owner
Introductions
Old 06-14-2011, 04:32 AM   #1
baker721's Avatar
baker721 is currently offline
My Model: z210 Shabah
My Engine: 350 Bravo III
Send baker721:
Default 1996 Z210 Shabah new owner
Hello all,
Sorry I havent done this sooner, I have be spending alot of time working on the boat and more time on the lake. I got her as a repo... no speakers or radio, engine runs okay but i have been spending alot of time search the form for information.
I have currently been having problems with the engine cutting out at high rpms sometimes but mostly in the hole shot. Also I am noticing oil coming out of the drain plug. Any clues as to what could cause these problems. I have a bravo III mercruiser 350 i think they are 24p props.
Like I said I am a new owner and not a mechanic.... so any help would be greatly appreciated.
Ill make sure to post more pics once I get her cleaned up.... She had been sitting outside since 2000 with no cover so the interior of the boat needs alot of work.
Thanks for the help
  • Old 06-14-2011, 05:28 AM   #2
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    Default Re: 1996 Z210 Shabah new owner
    The cutting out and not running consistent and smooth could be fuel related, make sure all is new and use some additive, and replace fuel filter.
    The oil is from an oil leak likely and ending up in the bilge area and exiting the drain. Use some rags, lights, mirrors or whatever and find the leak, it'll only get worse til you can find and fix.
    Nice find though, it looks to be a Limited Edition. Im sure you will bring her back to her glory days soon.
    Congrats on a rare boat.
    Zack
    1994 Z212 Shabah
    Old 06-16-2011, 08:28 PM   #3
    baker721's Avatar
    Send baker721:
    Thanks Zack... It looks to me like the oil is leaking from the drive oil reserve.... I checked the hoses but it looks like it just overflowed... I will keep an eye on it though. Can you think of anything else I need to check. Is there a place to check the gear lube in the lower unit??? Also, what is the best way to clean the interior of the boat... I have heard to use acitone.. is that true... Please help
    Old 06-16-2011, 09:22 PM   #4
    There is a lube reservoir for the outdrive located near the rear of the engine or possibly on the rear bulkhead.
    Acetone is one way to clean the interior but using those Mr Clean pads is far safer and just as effective.
    Old 06-17-2011, 03:12 PM   #5
    darkcalling's Avatar
    My Model: Z278 Limited
    My Engine: 502 Bravo III
    Gallery Images: 3
    Send darkcalling:
    Acetone only on hard surfaces if that gets on vinyl she will be dried out and crack for sure I would second the mr clean pads and soak the soft vinyls with alot of vinyl or leather conditioner and I do mean soak you might get lucky and if its not ripped it will drink it up and become nice and supple again. As for the oil leak if its not drive oil or valve cover related oil leakage check the rear of the engine gm small blocks back in the days were bad for rear seal leakage and as stated it only gets worse. Nice looking boat though good luck with her.
    Thank you darkcalling for this useful post!
    baker721 (06-21-2011)
    Old 06-20-2011, 04:51 PM   #6
    baker721's Avatar
    Send baker721:
    Thanks... more woes i think i am looking at replacing the alternator now... Its showing no charge.. Has anyone ever done this before????
    Old 06-20-2011, 11:33 PM   #7
    Zackattack's Avatar
    Send Zackattack:
    Alternator is no challenge to replace, two bolts and an electrical connection.
    Make sure you buy the CORRECT Marine alternator, not a cheapie auto alternator. Spend the money for the right one and you will be happy. And just make sure to tighten the electrical connection when done, should only be a one hour project to swap.
    Take a good look at the belts too, this may be a good time to replace if needed since you will have this one off anyway.
    Hope the best!
    Zack
    1994 Z212 Shabah
    Old 06-21-2011, 12:26 AM   #8
    Gallery Images: 3
    Send darkcalling:
    Yeah Zacks right its an easy job but don't cheap out I did and had to buy another one 2 seasons later lol. Lesson learned somethings are actually better when their made for the boat, belt change same time and you should be good in that department for years once the electrical connection is together a little squirt of silicone spray will really water proof the connection but go easy you only want it on the connect after its connected and no where else.
    Proud owner of a near new 1996 Mariah Shabah 210 efo Introductions 25 12-17-2018 11:44 PM
    New Talari z210 owner Dern72 Introductions 2 09-10-2010 03:47 AM
    1998 Mariah Z210 Shabah Proud Owner mark43 Introductions 1 08-17-2010 07:56 AM
    New Owner of z210 Talari...Power hatch oncman Original Mariah Talk 2 08-15-2009 09:28 PM
    1997 Shabah Z210 Captain Steve Introductions 4 09-23-2007 06:22 PM
    There are 215 users
