new 1999 z212 owner
Introductions
Old 06-24-2014, 12:59 AM   #1
boatinmo is currently offline
My Model: Z212
My Engine: 5.7 alpha
Send boatinmo:
Default new 1999 z212 owner
i bought this boat at a great price. Of course a boat this old has some problems with instruments. The compass sometimes spins but never points in the right direction. the gas gauge bounces, the depth finder reads 0.5 all the time and the speedometer doesn't work. The boat is in great shape and runs great. I'm sure I'll enjoy the boat
  • Old 06-24-2014, 01:04 AM   #2
    Default Re: new 1999 z212 owner
    Do a site search (top right corner of the screen) for those items you mentioned and you find lots of threads on those subjects.
    btw....welcome aboard!
    Old 06-24-2014, 01:09 AM   #3
    Welcome to MOC!
    Old 06-24-2014, 06:29 PM   #4
    watertoad is currently offline
    My Model: Z250 LE
    Send watertoad:
    I don't think any of these are really problems:
    Compass Gauge: tap on it a few times. Lots of the gauges have gunk/mold that builds up over time, and have to be tapped to break some of it up.
    Gas gauge bounces just like on a car, it has a float and that's what it reads. As it bobs around, it'll bounce.
    Depth finder: you cannot use it while driving, have to be sitting still for it to read properly. Try turning it on when the boat is sitting still in the water, with power on, engine off.
    Speedometer: Behind the out outdrive, you will see a thin rubber hose. Check to make sure the rubber hose doesn't have any rips/seams. The speedo pickup is a tiny little hole that is on the very edge of the back of the outdrive, make sure it isn't clogged.
    Welcome to the Mariah Owners club
    Old 06-24-2014, 06:50 PM   #5
    Not quite.... Compass? Possibly yes.
    Gas gauge? We do have a cure for that problem in our 'How To' section entitled "Fix your jittery fuel gauge" by RJobe.
    Depth finder: Cant use it while driving? Mine works while i'm driving. Usual cause for not reading properly is that the transducer has loosened from its epoxy mount.
    Speedometer: Absolutely. Hose has a habit of coming off the connection at the outdrive and the small hole in the front of the outdrive has a habit of getting plugged. To find out, remove the plastic hose from the back of the speedo and use a small air compressor to blow it out backwards towards the outdrive. Dont use too much pressure.
    hrayner (11-01-2014)
    1999 Z212 Shabah with 350 Mag indykoch Mariah Boats For Sale & Wanted 3 05-22-2012 03:14 PM
    1999 z212 Jim Rice Introductions 6 05-22-2012 10:13 AM
    1999 Mariah Z212 Shabah cessnaag Mariah Boats For Sale & Wanted 1 06-10-2011 12:35 PM
    1999 Mariah Z212 Shabah indykoch Mariah Boats For Sale & Wanted 3 12-05-2010 01:56 AM
    There are 322 users
