New Scottish Member
Introductions
Old 01-26-2014, 07:25 PM   #11
Tatham007 is currently offline
My Model: 252 bowrider
My Engine: 350 Mag bravo 3
Send Tatham007:
Default Re: New Scottish Member
hi
i have been scouring the country far and wide for a second hand boat and finally i have one a Mariah 252. if you want a second opinion on a UK BASED boat before you buy it just give me a call.
thanks
tats
doncaster
01302618578
Thank you Tatham007 for this useful post!
Stingray49 (01-28-2014)
  • Old 01-27-2014, 12:54 PM   #12
    Stingray49 is currently offline
    Send Stingray49:
    Andy how long did it take to get to wootton creak and how far was it ? your mariah looks great in the pics where were they taken? Hope to have some pics of the sabah soon , when it stops raining.
    Old 01-27-2014, 07:06 PM   #13
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Right let me see if I can do this?......lol
    Nothing better to do at the moment!
    The whole trip is about 10 miles, and apart from a bit of light editing the video is pretty much the complete crossing.
    If I was to put an exact time to it I'd say that it was about 25min's dock to dock.
    Taking into account the 6knot limits at both ends
    On that day and in that slight chop, I would say I was running high 40's (MPH)
    Still don't understand how my daughter can sleep through that!
    (1) Mercury yacht harbour river Hamble.(0:00)
    (2) River Hamble Cardinal (2:25)
    (3) Red Jet Ferries cross(2:45)
    (4) Running alongside the Red Jet(3:05)
    The Redjets run @ 38 knots which is about 44mph
    (5) Flying fish(6:05)
    (6) Peel Bank(10:05)
    (7) starters platform out side of Wootton Creek(10:58)
    (8) Wootton Creek
    Those 2 pictures were taken at Alum Bay.
    It's at the western end of the Isle of White, next to the Needles.
    Took them from my silly little paddling boat!
    Look forward to seeing them, and amen to the rain stopping!
    But I hear we've got the cold coming soon!!!!!!!
    Old 02-01-2014, 05:07 PM   #14
    Send Stingray49:
    Hi Andy, Dragged the Mariah out of the corner of the boatyard, so here is a taster of what we found,
    Did'nt take any photos of the inside or engine as it started to snow !! If this the state of the outdrive what will the engine be like ?????? Thanks for info on your photos very interesting, my Grandson always fell asleep when I started the engine and remained asleep even at 25 knots.
    Ron
    Old 02-01-2014, 06:58 PM   #15
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    My first reaction was "Oh my dear God!"
    But then a couple of years sat in salt water will do that to paint on the outdrive.....
    It could just be cosmetic, but it's a real bargaining chip.
    Tread carefully with this one, it's obviously been neglected.
    There could be a bargain under there or a money trap!
    You didn't happen to notice if the bung was out did you?
    (hard to tell in that second picture) Was the boat heavy?
    Thank you Andy b for this useful post!
    Stingray49 (02-02-2014)
    Old 02-02-2014, 12:53 AM   #16
    Looks like a project!
    Old 02-04-2014, 07:05 PM   #17
    domraga's Avatar
    domraga is currently offline
    My Model: 218
    My Engine: Volvo 5.7GL / SX-M
    Gallery Images: 32
    Send domraga:
    Hi Ron, seems all the brits are online tonight!
    I've got a 218 down south and did a complete rebuild of the boat in 2008-2010, new engine and restoration of the hull etc. Mine is also running an SX drive, will see if I can post before and after pics. Don't worry about the surface finish until you have had a good look at it, the white colour is outdrive antifouling so get the loose stuff off. I tried evry finish of paint on mine, including the proper volvo stuff but the best I have found so far is Epoxy two pack. Check the oil in the outdrive is clean, if not change oil and the o rings on the fill and drain. Check there is no corrosion or deposits on the trim cylinder shiney portions. Do not operate the trim until these are clean otherwise you can damage the seals. Change the red oil (ATF) if it is cloudy. If it is still red, the system should be ok. Exercise the trim. If the drive oil is clean, it will probably be ok. Budget for a new set of anodes and don't like the look of your trim sensor!These tend to be quite unreliable on the volvos anyway
    Regarding the engine, change the water pump impellor immediately, I would then treat her to some new oil and take the plugs out and spray some WD40 into the cylinders and leave them for a day or so. Try cranking with a fresh battery with the plugs out, it should turn over very easily. Put some new plugs in and start her up, but be prepared to retime. These engines are bombproof, they are very well built and should last forever if looked after. However, corrosion can be their worst enemy as most of the block is cast iron. If you don't know the history, budget to change the risers and manifolds. If these are in poor condition, cooling water can and will enter the cylinders and hydro-detonate which can cause broken rods, cranks etc.
    Finally, get that plastic cover off asap. Boats have to breath and the pastic will sweat all the interior. A good canvas cover should be no more than GBP500 or less.
    mikeyt likes this.
    Old 02-04-2014, 09:39 PM   #18
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    Where about's are you domraga?
    Old 02-05-2014, 05:44 AM   #19
    domraga's Avatar
    My Model: 218
    Gallery Images: 32
    Send domraga:
    I'm down south in Sandhurst, Berkshire.
    Boat is moored on the thames, where are you based?
    Old 02-05-2014, 06:27 AM   #20
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    Just outside of Southampton, on the edge of the New Forrest.
    I do most of my boating around the Solent but am willing to travel.
    Although looking at the state of my garden at the moment I could quite happily do a few laps in the boat here!
    How's the flooding up your way?
    Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
    There are 358 users
