New proud Mariah owner
Introductions
Old 07-27-2013, 10:32 AM   #1
melizondo81 is currently offline
My Model: Z202
My Engine: 7.4 Bravo III
Send melizondo81:
Default New proud Mariah owner
I just purchased a 1995 Z 202 with a 7.4 with Bravo III . however the owner before me seemed to like to tinker without knowing what he was doing. My seat height adjustment switch is not working along with cowl lift switch and the bilge switch also. I have had the boat out half a dozen times now and love the way it runs i just would like a little help if possible repairing the small things inside. Any help or advice is greatly appreciated .
  • Old 07-27-2013, 01:38 PM   #2
    Default Re: New proud Mariah owner
    Welcome aboard! "Tinkering" is a good thing and to be honest that's how many of us learn how things work. Generally when electrical things stop working on a boat its either due to a bad ground/broken or bad wire connection, failed fuse or a failed part. If u use a 12v test light then you can tell if there is power going to each of the items and if so, that will rule out the fuse / bad ground issue. With the bilge pump they are known to fail or get blocked with debris so if there is power going to it then the unit has either failed or is blocked. Try taking it apart to clean it out or better still, if its an original unit it has served you faithfully for 18yrs and its time to replace.
    The fuse panel is located up underneath the dash on the starboard side. You should be able to access it thru the headrest in the bow.
    Old 07-27-2013, 02:28 PM   #3
    My Model: Z202
    Send melizondo81:
    Thank you for your help and I look forward to learning as much as I can with everybody's help.
    Old 07-28-2013, 09:48 AM   #4
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Headrest Mikey? just how tall are you???
    Old 07-28-2013, 12:48 PM   #5
    Backrest for most people, headrest for the Mariah midgets. Its awkward as all hell but it can be done. I found it easier to lay on my back underneath the console and reach up.
    Proud owner of a near new 1996 Mariah Shabah 210 efo Introductions 25 12-17-2018 11:44 PM
    Proud Mariah boat owner Dogloop Introductions 6 06-17-2012 01:28 PM
    proud owner of a 1995 mariah davanti 24' lance Introductions 6 05-11-2009 01:38 AM
    Proud New Owner of 99 18' Mariah Shabah monirangel Introductions 11 03-13-2009 02:24 PM
    proud new mariah owner !!! MIEM Introductions 3 05-18-2008 07:11 PM
    There are 286 users
