new to me 1995 shabah z202
Introductions
Old 11-19-2012, 07:58 PM   #11
kjdevrou is currently offline
My Model: z202 shabah
My Engine: 5.0L alpha one
Send kjdevrou:
Default Re: new to me 1995 shabah z202
here are some before pics of the shabah z202 I just bought. this is how it looks now (same as the day i brought it home). I will get some after pics after I get it all cleaned up.
  • Old 11-20-2012, 02:10 PM   #12
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    Congrats on the new ride. Looks like some elbow grease will go a long way on that one. I'll be looking forward to seeing the after pics.
    Old 11-20-2012, 02:24 PM   #13
    allz28's Avatar
    allz28 is currently offline
    My Model: z210 Shabah
    My Engine: 5.7L Merc
    Send allz28:
    That interior looks darn good. Mine was covered in mold.
    I have the same problem with the gelcoat being faded. What is the best product to use to restore it?
    1996 z210 Shabah
    5.7L Merc/Alpha 1
    Old 11-20-2012, 02:52 PM   #14
    Send kjdevrou:
    Mikeyt said " Meguairs make a very good 3 step cleaning process that should put a shine back on the hull."
    I'm not sure where to get it. maybe mikeyt can help us out.
    Old 11-20-2012, 03:09 PM   #15
    allz28's Avatar
    Send allz28:
    oops, missed that in his post.
    1996 z210 Shabah
    5.7L Merc/Alpha 1
    Old 11-20-2012, 04:41 PM   #16
    "Meguiars Fiberglass Restoration Kit".
    It's available at West Marine, Bass Pro Shops, and even some Wal-Marts if they carry marine products. You can also buy online from a number of retailers.
    I've used it and can honestly say it works very well. Yes it's a little work, but the end result is well worth the time and effort.
    Also, for your interior, give the Mr. Clean Magic Erasers a try. They work wonders. There's all kinds of cleaning tips and tricks on the site!
    Old 11-20-2012, 04:58 PM   #17
    Send kjdevrou:
    thanks, I don't mind the work if the results are good.
    I might wait till spring to start cleaning. i don't want any cracks from everything being cold.(if I can keep my hands off it????)
    I'm also l thinking of waiting to start it til spring. I will most likely pull the plugs and spray some fogging oil in each cylinder and turn the motor over by hand, then just start her when the weather breaks. I figure its only 4 months from now. its going to be a long 4 months. maybe a quick vacuum wouldn't hurt
    1995 Mariah Shabah Z202 5.0l alpha one
    Old 11-21-2012, 04:45 AM   #18
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    Congratulations on a great boat!
    I would spend as much time on it as possible now if you have the time. It will only allow you the time to get all the little bugs worked out. I would recommend a marine mechanic now that things are slow go through the out drive and change fluids. You should get done now for much less than in the spring and if there are any issues you will have time to prepare for a repair instead of forced to do cause summer is here.
    Whatever pace you choose, you have a nice boat and will enjoy it very much. Congratulations.
    Zack
    1994 Z212 Shabah
    Old 11-21-2012, 12:20 PM   #19
    Send kjdevrou:
    thanks Zack.
    when you say go thought the out drive, what do you mean? what would need to be done? the boat only has 52 hours. I am more concerned about the motor sitting for the 3 years than the out drive.
    am I missing something?
    the out drive has new oil in it(3 years ago) and hasn't been in the water since. what would they do to go though it?
    Old 11-21-2012, 03:09 PM   #20
    Zackattack's Avatar
    Send Zackattack:
    Even though the fluid was changed three years ago, I would flush it with new as well as have a pro look at the bellows and make sure they have not deteriorated with time. Maybe someone else can chime in on whether or not the impeller would be fine. You would know it was fine though if you were to have it all correctly gone through is all I was recommending. There's a lot of value in the confidence of a newly maintained unit.
    I agree about the motor concern too, and I think I would use the off season to get a good mechanic to get her running and freshly tuned up to save on some cash as well as be confident you can use her for the entire season(when it comes).
    Just my opinion though. Nice looking boat.
    Zack
    1994 Z212 Shabah
    1995 Mariah Shabah z202 bnussbaum Mariah Boats For Sale & Wanted 2 08-20-2012 06:37 PM
    1995 Z202 Shabah - Glad to be a part! rjobe Introductions 7 07-18-2010 02:13 PM
    New 1995 Z202 Shabah Graphics spinks99 Original Mariah Talk 3 09-29-2009 09:42 PM
    There are 352 users
