Talari z220 Hello
Introductions
Old 01-08-2012, 11:08 PM   #1
cp55 is currently offline
My Model: z220
My Engine: 5.7 mag/ alpha 1
Send cp55:
Smile Talari z220 Hello
Mariah owners,
I am pleased to say I am one of you now. I am working on a 1994 Z220 talari it needs quite a bit of work but am truly impressed with the construction of this boat. I have the whole interior taken out and in the process of wet sanding and buffing the exterior. It seems to be coming right back in color and the interior with a toothbrush in the basement is starting to look good. Just wanted to say Hi.
PS *the only mechanical problem is a speedo not working its electric not vacuum and all the
components seem to be there including ground
*also I want to put the dividers between the motor and the sides to add storage I have seen
many with this does anybody think i will have a heat issue with the motor not getting enough
air?
Thanks again.
  • Old 01-09-2012, 03:52 AM   #2
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    Default Re: Talari z220 Hello
    Congradations and welcome. I think the great majority of Mariah's have those dividers on the sides of the engine, many incorporate a top piece as well for a storage area above the engine. I wouldn't worry about heat of the block since the engine cooling system is designed to keep it cool without the benefit of air for cooling. Mine is convenient to store a play tube on one side and a good spot to mount an amplifier and the sub on the other side without worrying about them coming into contact with the engine. You want to pay attention to what to wrap the inside of the panels with, the outside is carpeted but the inside has some heat resistant looking material, likely flame resistant.
    Keep us updated on the restore, welcome.
    Zack
    1994 Z212 Shabah
    Old 01-29-2012, 05:06 PM   #3
    markme is currently offline
    My Model: Talari 220
    My Engine: 5.7L Bravo III
    Send markme:
    I am currently involved in roughly the same project with my 94 Talari 220. My interior is out too. Soon I will be removing the old carpet from those dividers by the engine that you are talking about. Let me know if you want detailed measurements of the bare plywood pieces. They're a strange shape, not just a rectangle. This is all IF the engine area is the same design in a 220 and a Z220.
    Also, I'm considering using the reflective foil bubble wrap sold at Menard's for attics. I intend to use it for the thermal/sound insulation on the insides of those panels. I think it's fireproof. The best part... $15 will do the job with enough to redo the back of the bench seat too.
    Anyway, welcome and let me know if you need measurements.
    Old 01-29-2012, 10:25 PM   #4
    My Model: z220
    Send cp55:
    Thanks for the info. I just got the dash put back together everything works. started replacing the bulbs in the docking lights saturday. You have a great idea with the foil wrap i found the identical thing at menards with the foil and foam for sound deadening it has the sticky back and i will also use stainless staples. I sanded the plywood for the seats (2) that need to be repaired and installed new aluminum thread in inserts with stainless washers for the sundeck. Its been alot of fun also alot of work. Good luck and have a great day.
    Old 01-29-2012, 10:28 PM   #5
    My Model: z220
    Send cp55:
    Zackattack thanks. I have done quite alot of work but we are getting close. What a great boat the way it is built. Have a great day. Curt
    z220 Talari interior buchshot12000 Projects 2 04-08-2011 01:27 AM
    1993 Z220 Talari rjenkins Original Mariah Talk 1 01-14-2011 11:30 PM
    1996 Z220 Talari Ursla Introductions 1 06-15-2009 02:54 AM
    Just bought a 96 Talari z220 waynexax Introductions 1 06-13-2008 06:12 PM
    Z220 Talari BravoIII Introductions 1 08-13-2007 02:30 AM
    There are 316 users
