1994 23' davanti just bought this summer
Introductions
Old 11-12-2011, 05:23 PM   #1
vetteman87 is currently offline
My Model: davanti 225
My Engine: 5.7l bravo 1
Send vetteman87:
Smile 1994 23' davanti just bought this summer
hey there everybody
i am jim and just bought a 1994 23' davanti in late july! this is my 1st boat and i love it so far. i am from upstate new york and do most of my boating at saratoga lake or lake george. i have some issues with the boat : i can not gat my dash lights or my navigation lights to work, also my shifter is stiffer then heck to go into drive or reverse,my power steering doesnt feel like it works at all either. any and all help would be great.other things i would love to know is what pitch and size prop i should be using,how fast the boat is capable of.i have the 5.7 ltr with alpha 1. it had a 14.5 by 17 pitch prop and a back up 14.5 19 pitch back up.
thanks and nice to meet you all
jim
  • Old 11-13-2011, 08:35 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: 1994 23' davanti just bought this summer
    Hi Jim,
    Welcome to the club.
    Have you checked for power to the light switch yet? It's possible that it is simply a blown breaker.
    Does the motor stall when you attempt to shift. You didn't mention it so I assume no.
    Have you attempted to isolate where the stiffness is in your shifter?
    I would start by disconnecting the shift cable from the shift plate on the side of the engine and then operate the shifter. If it still feels stiff then the problem is in the shifter itself or the cable going to the shift plate. There is an adjustment on the underside of the shifter that sets the amount of friction on the shifter...so it doesn't move when you hit a wave. This may be set too stiff.
    If the shifter no longer feels stiff then the problem is the cable that goes from the shifter plate to the outdrive. These cables tend to go bad every five to ten years but usually cause stalling to go with the stiffness.
    I assume you have checked and there is fluid in the power steering pump reservoir. There is a valve on the transom assy that applies pressure and it could be stuck. Try spraying some WD-40 on the transom assembly and operate the steering back and forth with the motor running.
    Good luck.
    mikeyt likes this.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    1994 Davanti 225 454 Mag MPI seansmp8 Mariah Boats For Sale & Wanted 2 11-10-2011 03:27 AM
    1994 Davanti 225 Brochure? seansmp8 Original Mariah Talk 3 11-10-2011 12:39 AM
    Depthfinder on a 1994 Davanti 205 sanukc Original Mariah Talk 6 08-13-2011 03:15 AM
    1994 Z241 Davanti - $14,000 iamkeith Mariah Boats For Sale & Wanted 0 08-10-2010 11:22 PM
    1994 DAVANTI 225 on EBAY jonesjchad Mariah Boats For Sale & Wanted 5 05-14-2008 08:54 PM
    There are 290 users
