Got my first Mariah
Introductions
Old 09-08-2010, 02:48 PM   #1
MadMax is currently offline
My Model: Z225 Davanti
My Engine: 5.7 Alpaha I
Send MadMax:
Default Got my first Mariah
Well it is official.....I am now the proud owner of a 1995 Mariah Davanti Z225. I had it out on the lake and it ran flawless. It has a new motor 5.7 with only 26 hours on it. Having issues trying to figure out why the cuddy lights do not work and what supports the cushions when you put the two center cushions in to make the bed in cuddy. If anyone has a Z225 and can answer some questions would be highly appreciated. Live in Oregon so boating is coming to an end quick. Anyone on here live close or in Oregon??
  • Old 09-09-2010, 11:08 AM   #2
    Default Re: Got my first Mariah
    Hi MadMax, that great news indeed and congratulations on being a new Mariah owner!
    As for the lights, trace the voltage while checking the switch and wiring for corrosion or dirty dirty contacts or blown fuse/tripped circuit breaker.
    The cushions should be held up by either a set of aluminum rails or ones made from plastic. I believe this same question came up a few years ago, you can try the search function to locate the thread. I'll get back to you if I can find it.
    Are there any members in Oregon... Left click on "Community", located under the banner picture in the upper right corner of the page and select the Club's "Member Map" from the drop-down menu, then zoom in on the US then Oregon to see who's there. You're welcome to add your pin to the map as well, click here for the tutorial.
    Good luck,
    There are 216 users
