Help
Introductions
Old 08-03-2010, 12:28 AM   #1
ski33aurora is currently offline
My Year: 1990
My Model: 2150 xlc
My Engine: mercruiser
Send ski33aurora:
Default Help
I need help...I just bought a 1990 Mariah 2150xlc. I took it out 3 times now and the bilge in filling with water...alot!! Gallons are coming out when I turn on the pump. I took it to a marine mechanic...he said the all the hoses etc...are fine. He can't find where the water is coming from. However...there is a fresh water shower unit in the back of the boat. Where is the water intake for this? I found a hole in the upper port side....is that it? I'm a NEW boat owner....don't know anything about them!!! HELP
  • Old 08-03-2010, 05:44 PM   #2
    Default Re: Help
    Hi ski33aurora and welcome to the club!
    If the hole you're referring to is above the water like, most likely it's a water drain or if it's at the very back above the swim platform then it's probably the vent for the fuel tank
    I suggest you or your mechanic follow the shower hose back to where it gets it's water (something I would have thought the mechanic would have done anyway). Another thing, is your speedometer working OK? (I know it sounds funny, but a broken speedo tube will allow water in as it's under pressure when you're moving)
    Old 08-04-2010, 02:03 PM   #3
    My Year: 1990
    My Model: 2150 xlc
    Send ski33aurora:
    Default Re: Help
    Thank you so much for that information....they have never even suggested the speedometer...interesting.....but thank you again...I appreciate your help.
    Old 08-04-2010, 08:33 PM   #4
    Vacation Dave's Avatar
    Vacation Dave is currently offline
    My Model: 1995 Z220 Talari 7.4L Bravo I
    My Engine: 7.4L Bravo I
    Send Vacation Dave:
    Default Re: Help
    I had a cracked exhaust bellows. You may the mechanic check all of the bellows as well.
    VDave
    There are 233 users
