Hello everyone
Introductions
Old 04-02-2010, 04:52 AM   #1
ninoct23 is currently offline
My Model: Talari
My Engine: Mercrusier
Send ninoct23:
Default Hello everyone
Whats going on guys, thanks for letting me Join your club. I have a 1995 Mariah Talari and the guy I bought it off gave me no Info it and I am having problems with the electrical and shifting into Neutral. So any info you guys can give me would be great and I can contribute in anyway.. Thanks alot.....
  • Old 04-02-2010, 11:41 AM   #2
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Default Re: Hello everyone
    Welcome aboard.
    There are lots of members here with experience, so just post up whatever issues you might be having. Electrical gremlins are common on any boat. A good place to start is to clean all the contacts at the fuse block and even apply a some di-electric grease to keep things clean. As a contributing member, you have acess to the wiring diagrams, so that should help you trace where things are.
    Neutral shift problems might be as simple as an adjustment to the shift interuptor switch. A common adjustment on Mercruiser powerplants.
    My Mariah
    Old 04-03-2010, 02:05 AM   #3
    My Model: Talari
    Send ninoct23:
    Thanks for the quick response, I think your right about the electrical all the conections are bad, But where is the "shift interuptor switch"? thanks again have a good Easter weekend
    Old 04-03-2010, 02:33 PM   #4
    Z 202's Avatar
    Send Z 202:
    It's on top of the motor, at the back where the shift cable assembly is. It interrupts the engine momentarily to allow the clutch dog to disengage. Or the shift cable may need to adjusted or replaced.
    This is a good site for drive information: MerCruiser Tools and Supplies for the do-it-yourselfer
    My Mariah
    Thank you Z 202 for this useful post!
    mikeyt (04-05-2010)
    Old 04-05-2010, 03:55 AM   #5
    My Model: Talari
    Send ninoct23:
    Z 202 YOU ARE THE MAN!!!!!! The ground wire on the interuptor switch was causing all the problems. So I am just gonna replace that, and I tighten all the cables. Getting all the lights starting to work scrub all the corosoin off the fuse block. So thanks again I apperciate that
    Old 04-06-2010, 01:57 AM   #6
    Z 202's Avatar
    Send Z 202:
    Glad I could help.
    My Mariah
    There are 239 users
