Greetings and a question from new Mariah owner
Introductions
Old 09-09-2008, 04:05 PM   #1
CharliEcho is currently offline
Send CharliEcho:
Default Greetings and a question from new Mariah owner
Hello everyone. I just purchased a 1993 MX19 and I am very impressed with the quality, fit and finish of the boat. It has held up quite nicely over the years. This boat has a 4.3LX engine and I've discovered the following problem I hope someone may shed some light on. While cruising comfortably at around 2800-3000 rpm's on occasion the engine will lose power (like it's going to quit) then starts running again. It hasn't displayed this behavior at other power settings (nor during the test drive ). Problem seems to come about after hitting some wake. Also, on occasion the boat has quit when brought to idle abruptly and then will only run at high rpm's (won't idle). I am suspecting a problem with the choke plate? Any comments/advice greatly appreciated. TIA
Cheers.
  • Old 09-09-2008, 06:45 PM   #2
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Congrats on the Mariah!
    I'm not terribly familiar with carbs, but I know others here will chime in. First thing I'd do is change the fuel filter. It could be starving the engine at certain times, especially when hitting waves or abruptly changing speeds (possibly dislodging particles).
    Hope you find the problem! Post some pictures when you have the chance!
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 09-09-2008, 07:33 PM   #3
    Send CharliEcho:
    Thanks for the reply Ryan. First thing I did was replace all fluids and filters. Fuel filter was pretty nasty. I was hoping the clean filter and fuel would cure the problem. Will get some pictures soon.
    Carlos
    Mariah Horns Question Douglas Alderman Original Mariah Talk 33 04-09-2013 05:33 PM
    another Mariah owner illini1 Mariah Boats For Sale & Wanted 3 08-25-2008 08:47 PM
    New Mariah Owner water boy Introductions 2 07-23-2008 06:27 PM
    New Mariah Owner cacthedrac Introductions 4 07-11-2008 07:53 PM
    New Mariah Owner love2boat Introductions 2 04-01-2008 05:06 PM
    There are 219 users
