New to me 96 Talari 215
Introductions
Old 05-03-2020, 10:06 PM   #1
Danhillak is currently offline
My Model: Talari 215
My Engine: 5.7 Mercruiser
Send Danhillak:
Default New to me 96 Talari 215
Long story short, I got a "free" boat! It had been sitting for 4 years and was no longer being used....ran when parked sorta deal. Anyways, I got it running this weekend, once insured and registered, we'll take it to the lake. If it gets around, then the project begins! Paint and gel coat a re rough, vinyl is super rough, the cuddy smells like a 70s camper. Any tips out there on these boats as I go from this first test on the lake and beyond?
Dan
  • Old 05-04-2020, 12:41 AM   #2
    Lancer is currently offline
    My Year: 2003
    My Model: Z 235 Devanti
    My Engine: 7.4 Bravo 1
    Send Lancer:
    Default Re: New to me 96 Talari 215
    how long did you run it on muffs. change oil, drive oil, look for water in oil, fuel water separator, spark plugs and wires.dont be to adventurous on the first trip. but good luck and welcome
    Old 05-04-2020, 12:54 AM   #3
    My Year: 2003
    Send Lancer:
    as soon as you launch, check for leaks. check.
    to make sure your charging, check for a cracked bellows
    Old 05-04-2020, 03:58 PM   #4
    Send Danhillak:
    Ran it till it came up to temp and I could verify no engine leaks, alternator was working, bilge pump, trim, fwd, reverse, out drive. Fuel tank is freshly siphoned, gas was def bad. I'll take her slow on the first go round, thanks for tips.
    Old 05-04-2020, 06:02 PM   #5
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Grease gimble bearing and motor coupler.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 05-04-2020, 06:34 PM   #6
    Send Danhillak:
    Added to the list, I didn't even know that there were grease fittings on there
    So gimble just uses same grease as a U-Joint I'm assuming?
    Is there special grease for the coupler?
    Old 05-04-2020, 07:19 PM   #7
    My Model: Z280
    Motor coupler uses EP grease due to high pressures between the steel drive shaft splines and the softer aluminum splines of the motor coupler. You don't want the coupler to fail, need to pull the engine to change it. I'm interested middle of that job now.
    Gimbal bearing uses water proof trailer grease.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Danhillak (05-04-2020)
    Old 05-05-2020, 07:33 PM   #8
    Mwb712 is currently offline
    My Model: 182 Barchetta
    My Engine: MCM 4.3 Litre LX
    Send Mwb712:
    Use baking soda and a room deorderizor to get the smell out
    Sent from my iPad using Tapatalk
    Diff between Talari 220 vs Talari Z220 ckstiles Introductions 2 04-29-2013 02:23 AM
    Difference between 240 Talari & 240 Z Talari ? wunn Original Mariah Talk 3 07-03-2009 03:03 PM
    There are 286 users
