Newbie says Howdy!
Introductions
Old 03-18-2020, 04:46 PM   #1
GetnAway is currently offline
My Year: 1991
My Model: 1900Z
My Engine: 4.3L V6 Alpha One
Gallery Images: 1
Send GetnAway:
Default Newbie says Howdy!
GetnAway
Here I am as a brand new member of the Mariah Club. So I wish to say howdy to all other members and hope to get some great help. My wife and I just bought a 1991 Mariah 1900Z and love this boat. Even though we have not had it in water yet due to a bad coupler. It appears to have been caused by the port side motor mount came loose from the fiberglass support and chewed out the holes. I will be pulling the 4.3 V6 as soon as the weather gets better. And try to find a way to repair the fiberglass under the motor mount. Wish me luck as I am new to boat repair but I have plenty of other related repair knowledge. :-) Any advice on the motor mount problem is greatly appreciated. I am ready to go boating when it warms up here in Iowa. My user name is GetnAway which is the name we gave our new 1900 Z.
Now I need to figure out how to post images???
  • Old 03-18-2020, 04:58 PM   #2
    Lancer is currently offline
    My Year: 2003
    My Model: Z 235 Devanti
    My Engine: 7.4 Bravo 1
    Send Lancer:
    Default Re: Newbie says Howdy!
    after you pull the motor and drive(pull first), drill some cores on the mounts and get a feel for the structures. if that are in good shape, you can fill and seal. also, while you have it out rebuild the carb. trust me you'll be happy you did.
    Old 03-18-2020, 05:08 PM   #3
    My Year: 1991
    My Model: 1900Z
    Gallery Images: 1
    Send GetnAway:
    Thanks Lancer,
    Do you know if I would be able to add a piece of stainless steel or alum under the fiberglass support to give it strength? It has been so nasty weather wise I have not been able to do a full investigation to the mount problem but the port side mount has two pieces of 3/4" x 3" x 1/8" thick plates added on top. To me it looks like a BANDAID fix. I wish I knew how to add a photo of the mount. I am sure that you would agree it is not a good fix for the problem.
    Old 03-18-2020, 05:48 PM   #4
    My Year: 2003
    Send Lancer:
    you have to fix it right.its why the coupler when out.there is a guy on you tube that put together a series on fixing the whole stringer and engine mounts system on a sea ray. his name is friscobob.you will have to look through the series for the right episode. it doesn't look hard but a little time consuming.also while you in there, look at the transome.these boats used good marine grade wood so the damage is probably limited, but you have to make sure if you plan on making it a labor of love. I have a 95 that I love so will never sell it but it's what I like to do.
    Old 03-18-2020, 06:03 PM   #5
    My Year: 1991
    My Model: 1900Z
    Gallery Images: 1
    Send GetnAway:
    I agree I want it done right for sure. I have watched FriscoBoater's videos on YouTube and I will have to go back to watch that episode again. I remember it was quite a detailed series by Jay from Frisco, TX
    Thanks again Lancer. I will try to post back when I get the repairs done. Maybe it will help others.
    Old 03-18-2020, 06:09 PM   #6
    My Year: 2003
    Send Lancer:
    keep us informed and maybe take a video.we may need the info on our older Mariahs.great luck.remember you can take your measurements off the good mount.that will help a lot.
    GetnAway likes this.
    Thank you Lancer for this useful post!
    GetnAway (03-18-2020)
    Old 03-20-2020, 01:33 PM   #7
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Welcome to the club. Make sure you purchase a good quality alignment tool to ensure you don't take out your new coupler...once you are finished with your mount repairs.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 03-20-2020, 02:58 PM   #8
    My Year: 1991
    My Model: 1900Z
    Gallery Images: 1
    Send GetnAway:
    Hi Steve and thanks for bringing that up as I have a tip to share on that issue.
    But speaking of the alignment tool which I did buy!!! Before I removed the motor I wanted to check the alignment for a reference. I could not even get the Merc tool into the striped out coupler. So I used a 3' long very straight 1 inch hardwood dowel and inserted it into the coupler. I found that the motor is way, way too high in the front. The dowel makes a great first test for alignment. Also if it is so far out of alignment use the dowel to get the motor close enough to then use the mercury approved tool.
    I have four boats I am working on that need outdrives gone through and Gimbal repairs. So I bought all the Mercury tools for Outdrive and Gimbal service. I have more money in tools & manuals now than I paid for my 91 Mariah 1900Z :-(
    Old 03-20-2020, 04:04 PM   #9
    My Year: 1991
    My Model: 1900Z
    Gallery Images: 1
    Send GetnAway:
    LANCER & HUDSON RIVER STEVE
    Here is a picture of how a Marina tried to fix a loose motor mount on my 1991 Mariah 1900 Z. It caused the coupler to strip out the splines. And damaged the driveshaft too. [IMG]The Mariah Owners Club - Gallery - Bad fix for a loose motor mount by a Marina[/IMG]
    Old 03-21-2020, 01:50 PM   #10
    My Year: 2003
    Send Lancer:
    that's a marina they should know better. the problem is that people just want to fix things just to be able to sell things.
    Howdy Need some help! Littlejo Introductions 4 06-25-2019 03:36 PM
    Howdy Folks SolSeeker Introductions 0 02-07-2017 02:41 AM
    Howdy From Texas! Texas Thunder Introductions 1 09-08-2016 09:00 PM
    Howdy Sdowney Introductions 5 03-17-2010 12:10 AM
    Howdy buddyboy Introductions 2 06-24-2008 05:48 AM
    There are 307 users
