Alarm Sounding- 1995 Barchetta 182
Introductions
Old 08-26-2019, 08:18 PM   #1
partgsguy65 is currently offline
My Model: 182 Barchetta
My Engine: 4.3 Vortec
Send partgsguy65:
Default Alarm Sounding- 1995 Barchetta 182
I have a 1995 Barchetta with the 4.3 and the last time I had it out, I killed the engine for a while. When I restarted the engine, a continuous alarm sounded. Not the same one that sounds when switching on, before starting. Everything appeared normal. What I did notice, is when the the boat rocked back and forth, the alarm would sound and turn off in conjunction with rocking. I thought it might have something to do with the bilge pump...It finally stopped as we headed in, but I'm concerned as to what the source may be. I will admit, I've never owned a boat until this one. We've had it out several times this summer with no issues at all. Until now. I have no owners manual, and I have no clue as what the problem could be. Any suggestions?
  • Old 08-26-2019, 08:45 PM   #2
    Default Re: Alarm Sounding- 1995 Barchetta 182
    Read the STICKY in the Mercruiser section / Problem is related to either the engine oil level & overheating or outdrive oil level
    1995 barchetta 95 riverboat Projects 2 07-01-2019 06:16 PM
    '96 Talari - alarm sounding at idle only, then she died :( mike523 Original Mariah Talk 24 07-31-2016 11:30 PM
    Alarm Sounding & Engine Dying??? smcomia Original Mariah Talk 11 04-30-2012 03:44 AM
    Alarm Sounding, but pressure/temperature look fine? aggressivebuggy Sea Fox - Mariah Talk 5 06-29-2009 04:59 AM
    1995 Barchetta 182 peppe Original Mariah Talk 6 06-06-2008 06:13 PM
    There are 351 users
