Performance
Introductions
Old 08-10-2018, 03:15 PM   #1
Jdchandler2 is currently offline
My Model: 200 Talari
My Engine: 5.7L Mercruiser Alpha
Send Jdchandler2:
Question Performance
So I have a 1994 200 Talari. Just trying to gain some basic performance knowledge. It has the the 5.7L Alpha One. @WOT I'm hitting about 4200-4300 rpm with it trimmed out to the top speed I can get it to @ 48 mph. That was with about a half tank of fuel and only me in the boat. I'm not sure what prop details are with the current prop I have on it. So my first question is, do these numbers sound about right? I would think that with having the 5.7 my top speed would be around 55 mph. I know that prop diameter/pitch/cup all have an affect on top speed as well as rpm, so I know I'm shooting in the dark with not having the prop info on hand at the moment. But it seems I would be able to get some more rpm's out it and a few more mph as is.
  • Old 08-10-2018, 03:25 PM   #2
    Send Jdchandler2:
    Default Re: Performance
    Ok so for further reference here is the numbers from the prop...
    Quicksilver 48 163 16 A5 19P
    I'm assuming it's a 16-19
    Old 08-12-2018, 01:23 AM   #3
    Did you read any of the three STICKYS at the top of the Prop Talk Forum ??
    Recommended WOT RPM Ranges for Mercruiser Sterndrives: 5.7 L (A1) 250hp 4400-4800 rpm at WOT 1.62 gear ratio
    You have the right pitch prop at 19 so either your gear ratio is different or more likely your prop has been "repaired" at some point and is no longer a 19" pitch
    « Trim | Performance »
    Performance Jdchandler2 Introductions 1 08-12-2018 01:23 AM
    Performance question bboy012003 Sea Fox - Mariah Talk 8 11-17-2013 03:02 PM
    272 performance rickvr Boating 101 0 08-12-2012 02:05 PM
    182 performance question bbrophy58 Original Mariah Talk 2 11-26-2009 02:50 PM
    212 engine performance dieselwiezil Original Mariah Talk 20 06-19-2008 04:58 PM
    There are 333 users
