Excellent and Superb
Introductions
Old 05-27-2008, 02:06 PM   #1
jtlyons302 is currently offline
My Model: 1997 Z202 Shabah 350 Mag with Alpha One Outdrive
Send jtlyons302:
Default Excellent and Superb
I have a 1997 Z202 Shabah w/ 350 Mag and Alpha One outdrive. The forward reverse linkage seems to be going out of adjustment. I have adjusted at the engine side but I believe the problem is at the helm forward reverse throttle lever with engagement in reverse being the main problem. How can I access behind the lever to check for aadjustment there. Thanks for any help. Awesome boat!
  • Old 05-27-2008, 03:13 PM   #2
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    I'm not sure without seeing pictures, but mine has a panel that holds the throttle to the wall. It comes off by unscrewing the decorative buttons (they hide the actual screws holding the panel). Then you can unscrew them and remove the panel.
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 05-27-2008, 06:40 PM   #3
    Send jtlyons302:
    Thanks for the info. Great to be part of such a great club!
    Old 05-27-2008, 08:19 PM   #4
    Welcome aboard JT. !
    Old 05-28-2008, 12:20 AM   #5
    That's what it's all about, people helping people!
    Welcome aboard jtlyons302, if you have some pictures of your Z202 and upload them to the Gallery so the rest of us can admire it! For a tutorial on uploading to our gallery, Click here.
    We also have a Member Map, so take some time to stick your pin on it. Here's how to add your pin: Click here
    Lastly, we have a growing library of manuals, brochures, wiring diagrams, and all sorts of information relevant to Mariah's, the stern drives and equipment. All of these are available to our contributing members. Click here to see what each level has to offer.
    If you need any help getting around the Forum, just give a holler!
    Old 05-30-2008, 11:36 AM   #6
    Send jtlyons302:
    Pics of my boat are in the gallery under jtlyons302. Hope you enjoy them.
    Old 05-30-2008, 04:05 PM   #7
    Hi jtlyons302
    Great looking Z202 Shabah you got there! Is that a Pyle amp your running? How do you like the amp?
    I was wondering what that metal rail assembly on the back of your trailer, under the port side was for?
    Old 05-30-2008, 07:15 PM   #8
    Send jtlyons302:
    Yes it is a Pyle amp and it works great for the boat. It's a marine model with input output adjustments and also frequency cutoff levels and a LED power output meter that changes from green to red so you know how to set the power thresh-hold as to not overheat the unit due to distortion. That is a 2" receiver for pulling a wave runner off the back of the trailer. Thanks for the positive comments. Everyone at the lake can't believe the boat we have for the money spent, let alone the power driver seat!
    Old 05-30-2008, 07:26 PM   #9
    Thanks for the follow up jtlyons302, I'll have to look into these amps!!
    It's the little things that get them... but that's what Mariah's are all about,
    Old 05-30-2008, 08:18 PM   #10
    Great story, a few days ago I took my boat to the local Sea Ray dealer for service (used them for years, and one of the only trustworthy Mercruiser certified service facilities around)....
    Long story short, the Mechanic calls me up on my cell phone and asks "What's this code box thing on the dash, do i need a code number to start this boat? Man, I've never seen half of this stuff before, they don't put that kind of stuff on Sea Rays"
    My old Sea Ray salesman told me one of Mariah's advertising campaigns back in the day was "The Boat Sea Ray Owners are Upgrading to".... Then he told me how lucky I was to find a Mariah.
    There are 399 users
