1997 Mariah 242 Shabah
Introductions
Old 07-02-2017, 11:29 AM   #1
TanMcGan is currently offline
My Model: Z242 Shabah
My Engine: 454MAGMPI Bravo III
Send TanMcGan:
Default 1997 Mariah 242 Shabah
Hello all,
I am a new owner of a 1997 Mariah 243 Shabah, bought in February. My boat has the 454 MAG MPI engine with a Bravo III drive. I have been very happy with the boat so far but I do still have some gremlins to sort out. First one will be a new steering cable. Anyone happen to know the appropriate length cable for this boat? Also will one of these be a suitable replacement (http://www.easternmarine.com/Rack-Pinion-Steering-Kits)?
  • Old 07-02-2017, 01:21 PM   #2
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    Default Re: 1997 Mariah 242 Shabah
    Teleflex was the company name of the original steering components. It has been acquired by Seastar but the cables are still the same MOSTLY. You should be able to find the part number for the cable about 2 feet from the end that attaches to the steering rack. It will be something like "SSC134xx Teleflex USA ..." where the xx is the length in feet. Mine was painted over the other markings and is hard to read. Keep in mind that not all components are compatible with the older parts. For example, you may not be able to fit your tilt steering wheel adapter (if any) to the new cables. In a case like that you would have to buy all new parts.
    Is there damage to the cable? I replaced mine to remove some of the steering play and it did not help much. I ordered one of the same ones that are shown in your link. Also, if you removed the tilt mechanism, the rack will not mount correctly due to clearance issues.
    Bottom line: I don't recommend replacing it unless there is an obvious defect because you may have more issues trying to install it.
    Thank you GaryDoug for this useful post!
    Firestone (07-02-2017)
    1997 Z198 Mariah Shabah wredskinsfan32 Mariah Boats For Sale & Wanted 0 10-02-2013 03:04 PM
    For Sale-1997 Mariah 198 SE Shabah Shabah 198SE Mariah Boats For Sale & Wanted 3 07-08-2012 11:18 PM
    1997 Mariah 198 Shabah lrkn9117 Mariah Boats For Sale & Wanted 0 09-09-2011 01:13 PM
    1997 mariah shabah auspiciousarcher Mariah Boats For Sale & Wanted 0 03-08-2011 09:04 PM
    Have a 1997 Mariah 198 Shabah picked out! lrkn9117 Introductions 3 07-12-2009 01:45 PM
    There are 233 users
