New owner wants to add switchable exhaust to my thru hull
Introductions
Old 06-11-2017, 05:56 AM   #1
Bcm_andres is currently offline
My Model: Z215 Talari
My Engine: 5.7ltr Merc Alpha one
Send Bcm_andres:
Post New owner wants to add switchable exhaust to my thru hull
Hi guys, first post here. I just bought a 1996 Talari 5.7 mercruiser w/ thru hull option. I love it but want to install the...
EMI Silent Select System
...my y pipe is still in place and capped off. The y pipe is oval and the diverters / existing thru hull tubes are round. Dose the rubber connector sleeve w/ double clamps just form to the oval end and round diverters ends? Will that work for converting the two shapes?
Thanks everyone,
tbrookens and Firestone like this.
Thank you Bcm_andres for this useful post!
tbrookens (06-11-2017)
  • Old 06-12-2017, 11:11 PM   #2
    My Model: Z202
    Send Firestone:
    Default Re: New owner wants to add switchable exhaust to my thru hull
    Not sure on the connection from oval to round but here are some pictures I took of mine last year.
    John
    Thank you Firestone for this useful post!
    Bcm_andres (06-21-2017)
    Old 06-21-2017, 02:24 PM   #3
    Send Bcm_andres:
    What brand of manifold switches are in the picture?
    Old 06-21-2017, 03:07 PM   #4
    My Model: Z202
    Send Firestone:
    Not sure. They were factory installed. I will try to see next time I am out.
    John
    Old 06-21-2017, 03:18 PM   #5
    MTH
    MTH's Avatar
    MTH is currently offline
    My Model: Shabah 202
    My Engine: 5.7L A1
    Send MTH:
    I'm pretty sure mine was a factory installed system too, looks just like those pictures, and it has the Corsa name on it.
    99 Shabah 202 5.7 A1
    Thank you MTH for this useful post!
    Firestone (06-21-2017)
    Thru hull exhaust tom112 Original Mariah Talk 0 01-10-2015 04:45 PM
    Thru Hull Exhaust my97camaro Original Mariah Talk 12 10-26-2013 02:11 AM
    Thru Hull exhaust doucas Original Mariah Talk 1 02-15-2012 05:25 PM
    thru hull exhaust switch shopboy Original Mariah Talk 2 07-14-2011 12:54 AM
    Thru-Hull exhaust 845paulg Projects 6 10-25-2010 09:55 PM
    There are 292 users
