thru hull exhaust switch
Old 07-11-2011, 11:02 PM   #1
shopboy is currently offline
My Model: 202 shabah
My Engine: 5.7L alpha 1
Send shopboy:
Default thru hull exhaust switch
Good evening, I have just bought a 96 Shabah 200, thethru hull exhaust switch stopped funtioning on my second day out and I am trying to find out where the fuse panel might be. there is still power to the switch but nothing happens when you turn it on. this was a one owner boat with 330 hours on the meter. any guidance would be appreciated as I have blown my wad on the boat and cannot scrape together the sheckles to get into the manual portion of the website.
  • Old 07-12-2011, 04:30 AM   #2
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    Default Re: thru hull exhaust switch
    On mine there is a breaker(red button) on a bracket near the exhaust. Go to the wires on the exhaust diverters and follow the red wires, you should find that button and possibly an inline fuse too.
    Zack
    1994 Z212 Shabah
    Old 07-14-2011, 12:54 AM   #3
    TMRoper1669 is currently offline
    Send TMRoper1669:
    The Famous RED BUTTON, if you reset that button eveything should go back to normal, if not be sure to check you have power to the switch.
    Thru Hull Exhaust my97camaro Original Mariah Talk 12 10-26-2013 02:11 AM
    Need Exhaust Switch Help Andy-Z202 Shabah Original Mariah Talk 1 06-17-2011 12:14 AM
    Thru Hull or captians choice exhaust 99Z242 Projects 9 03-29-2011 11:52 AM
    Thru-Hull exhaust 845paulg Projects 6 10-25-2010 09:55 PM
    THRU HULL EXHAUST for a 218 Shabah JENZO Original Mariah Talk 13 09-19-2009 03:27 PM
    There are 338 users
