New to boating
Introductions
Old 08-26-2016, 05:46 PM   #1
Sakurasan is currently offline
My Model: Davanti 225
My Engine: V8, inboard
Send Sakurasan:
Default New to boating
Hello everyone!
I am new to boating and just recently replaced the power steering hoses but now there is a leak in the front near the reservoir. Should I replace the entire power steering unit or just continue to pinpoint the areas affected and replace each one as they come up? It's a 94 Davanti 225, if that helps. Inboard motor/prop
Kat ^_^
  • Old 08-27-2016, 01:08 AM   #2
    My Model: Z276
    Send Brian Belcher:
    Default Re: New to boating
    Hello !
    So, you have a NEW leak after replacing the hoses? If so, sounds like you need to redo your connections. Maybe you don't have the new hose tight enough? Or. is that even where the leak seems to be coming from? The res tank is part of the pump? Or is the res a seperate tank, away from the pump? What I;m actually getting at is, is the leak actually the power steering res or is it possibly the lower unit oil tank.
    new to boating roger allen Introductions 1 11-11-2014 03:19 PM
    New to Boating sanukc Boating 101 8 04-10-2011 02:00 PM
    new to boating good times Introductions 1 07-12-2010 06:54 PM
    New to Boating D & K Introductions 10 04-26-2010 09:50 PM
    New to Boating taunilynn Introductions 3 07-07-2009 12:18 PM
    There are 253 users
