dave s
Introductions
Old 08-08-2016, 02:53 AM   #1
dave s is currently offline
My Model: 212 shabah
My Engine: 305 yamaha
Send dave s:
Default dave s
Hello all mariah owners.Owned mine for a while and did not know about owners club.Really enjoy my boat even if it has a yamaha i/o. Lucky to have a yamaha dealer about a mile away.Would like to get a few more mph.Any suggestions? We clocked at 47 mph using gps.Thanks
  • Old 08-08-2016, 03:10 AM   #2
    My Model: Z202
    Send Firestone:
    Default Re: dave s
    Welcome to the club Dave! Yamaha 305 is a V8 correct? Do you know what is the hp and prop you are running? Post some pictures when you get a chance.
    John
    Old 08-10-2016, 09:15 PM   #3
    Send dave s:
    Default Re: dave s
    dave s here Anyone who could tell me how to change the foot oil in a yamaha i/o.Have paid to have it done in the past but want to do my own maintenance .Thanks
    Old 08-11-2016, 02:15 PM   #4
    CHICKS75's Avatar
    CHICKS75 is currently offline
    Status: I got this...
    My Model: 210 Z L.E. SHABAH
    My Engine: 5.7 Alpha-One Gen II
    Gallery Images: 15
    Send CHICKS75:
    Default Re: dave s
    Gonna have to give a little info to get info..
    1998 Shabah 210Z L.E.
    5.7L Alpha-One, Gen II
    Old 08-11-2016, 05:19 PM   #5
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: dave s
    I've never worked on a Yamaha outdrive but I assume they are a pretty close copy to either a Mercruiser or Volvo Penta drive. Tilt the drive all the way up. Remove the lower drain screw located on the starboard side of the drive at the bottom of the bullet then remove the upper vent screw usually located on the right side at the top of the drive. Let the oil drain completely. To refill with drive lube, purchase a quart bottle oil pump available at any marine store. Install the pump in the lower fill screw hole. Tilt the drive so it is fully down. Pump the recommended fluid until it just starts to come out of the upper vent screw hole. Install the upper vent screw with a new gasket then remove the pump and install the lower drain screw with a new gasket.
    CHICKS75 and Firestone like this.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    The Following 2 Users Say Thank You to Hudson River Steve For This Useful Post:
    dave s (08-15-2016), pllevine (08-30-2016)
    Old 08-15-2016, 03:01 AM   #6
    Send dave s:
    Default Re: dave s
    Thanks a bunch for that info.Will give it a try and let you know how it comes out.Thanks again dave s.
    Old 08-29-2016, 03:38 AM   #7
    Send dave s:
    Default Re: dave s
    Dave S here Has anyone tried iridium spark plugs in your boat?Put some in my 66 mustang and man what a improvement.
    There are 268 users
