New Member and maybe a Mariah Owner 2morrow
Introductions
Old 07-22-2016, 12:07 AM   #1
cvking is currently offline
My Model: Shabah 202
My Engine: 4.3 Volvo Penta
Send cvking:
Default New Member and maybe a Mariah Owner 2morrow
Hi guys I've been reading threw the forum and I found the buying tips. But im looking for opions on a 1994 Shabah 202 with a 4.3 Volvo Penta Duo drive. It seems to be in great shape by the pictures with a new interior this year. Hull could probably stand a waxing but it looks great. I didn't know much about the Mariah brand but I have been researching all day and haven't found very many negative anything's. So what should I be on the lookout for? The boat is about 2 hours away from me and owner says the speedometer is the only gauge that doesn't work everything else is mechanically sound. I just don't want to get there and over look something and I got him down to 4600 with a 98 model double axle trailer. Does this sound like a fair deal? It isn't much under Nada value but after researching these boats it seems like a steal. Thanks for any input I really need it.
  • Old 07-22-2016, 04:51 PM   #2
    My Model: Z202
    Send Firestone:
    Default Re: New Member and maybe a Mariah Owner 2morrow
    Look like a nice boat and the price seams fair as long as the hull and motor are in good shape
    John
    Thank you Firestone for this useful post!
    cvking (07-26-2016)
    Old 07-22-2016, 04:53 PM   #3
    My Model: Z202
    Send Firestone:
    Fyi the speedo gauges are notorious for not working. It might just be plugged since they work on water pressure from an inlet on the outdrive. Check the feeds for more information.
    pllevine likes this.
    John
    cvking (07-26-2016)
    Old 07-23-2016, 12:32 AM   #4
    scaverly is currently offline
    My Year: 1991
    My Model: MX22c
    My Engine: 5.0 Alpha 1
    Send scaverly:
    cvking . if you take compressed air and push it thru the small opening on the from side lower on the outdrive , the gauge should move , if not you may have an obstruction in that opening or the hose is plugged somewhere else. On the leading edge of that drive you will see the actual hose exit about 5 inches higher , take it off and do the same test , you will then know if it is the drive or the speedo .
    Shawn
    Old 07-23-2016, 05:05 PM   #5
    Hunter12345's Avatar
    Status: Silver Contributor
    Gallery Images: 2
    Send Hunter12345:
    Lol! Does it come with that massive subwoofer under the drive console? Nice looking boat, your going to like that duo drive!
    1998 shabah 180
    5.7l 350 mag
    Bravo III
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Thank you Hunter12345 for this useful post!
    cvking (07-26-2016)
    Old 07-24-2016, 03:15 AM   #6
    My Model: Z202
    Send Firestone:
    Lol I was at Lake Powell in the early 90's and saw a boat with 2 big speakers mounted back at the water skiier. Little did I know they were a trend setter and every wake boat now has them. Let that big old sub rock!
    John
    cvking (07-26-2016)
    Old 07-24-2016, 03:41 PM   #7
    Send cvking:
    Hey guys thanks for the opinions. Lol and yeah it has a sub but it's been relocated to the engine compartment in the rear. Sounds great I might add. So we bought the boat carried it out yesterday runs great. I do have a few other questions tho. When we get up around 3500 rpms just crusing across the water it sometimes gets to leaning to the right in the water and we were loaded evenly in the boat. Any ideas or is this just something that happens? also in the engine compartment my bilge pump kicks on quite a bit like ever 30 mins or so. I've looked but can't see where water is coming in from the inside but on the back between drive and the hull the there's what looks like a flex pipe that is broke could that be my leak? Sorry for all the questions but this seems to be the go to place for all things Mariah.
    Old 07-24-2016, 04:43 PM   #8
    My Model: Z202
    Send Firestone:
    Yeah I would check the water issue out in detail. My bilge pump almost never comes on. Not sure on the leaning but there are many different things that could cause it. Is it only at 3500 rpg? What speed?
    John
    Old 07-25-2016, 04:05 AM   #9
    Send cvking:
    Ok guys I went out again today and did some looking and found that the ujoint bellow is broken. What is involved with changing this out? Also I'm seeing that I'm probably gonna need to change the gimbal bearing and ujoint correct? Anything else I should be looking for?
    New to me Mariah Shabah Z255 1996 long time member now owner. tpdtopcop Introductions 4 02-18-2015 11:09 PM
    Brand new MARIAH Club member and on Monday proud new owner if a MARIAH 2600 Z! Cheshire Introductions 13 04-21-2014 08:01 PM
    new member/Mariah owner pvtfrank Introductions 7 04-11-2014 11:02 PM
    New Mariah owner and Club Member Snoopinrob Introductions 2 06-29-2011 01:03 PM
    new member potential new mariah owner fl_bill Original Mariah Talk 9 05-09-2010 03:58 PM
    There are 258 users
