Engine problems
Introductions
Old 09-01-2016, 03:57 PM   #11
My Model: Z276
Send Brian Belcher:
Default Re: Engine problems
I'll be breaking my response up into pieces to give others a chance to chime in.
The theory of gas continuing to pump in after shut down. Not likely. The fuel flow is shut off after the bowl fills up by the needle and seat. As the bowl fills up, the float floats up and closes off the fuel.
The ONLY path for fuel to flow is past the needle and seat.
Let's make a hypothetical
Let's say the fuel is leaking AFTER the needle. The bowl level would drop and the float would drop and the needle would open. Now there is a path for flow BUT, the pump is not pumping since the engine is not running.
If you have an electrical pump, and the electric pump continued to run after shut down, than a definite yes to your theory of gas continuing to flow after shut down. The pump would keep filling filling up the bowl as it drained/leaked down.
Another scenario is if the fuel cell was higher than the carb. A syphen COULD be created and flow could continue. But. Highly unlikely.
More later....
    Engine starting problems wackyd1 Original Mariah Talk 2 10-14-2012 02:58 PM
    Engine stalling problems again... theeasynine Mercury MerCruiser 0 06-17-2012 03:23 PM
    Engine problems truckingeorgia79 Original Mariah Talk 29 05-12-2012 11:07 PM
    Mercruise 3.0L Engine Problems Marci Sadler Mercury MerCruiser 5 05-28-2010 09:26 PM
    3.0L engine problems pimpadelic Mercury MerCruiser 7 05-16-2009 08:26 AM
    There are 210 users
