Hello from Arkansas!!
Introductions
Old 03-24-2015, 02:24 AM   #1
outacontrol is currently offline
My Model: 2000 Z
Send outacontrol:
Default Hello from Arkansas!!
Just purchased a 93 2000Z. I have very little history on the boat, will the HIN provide me with much? And how do I learn how to decipher it? Pretty sure it's not the original motor, has a Chevy 350 in it, hooked to a Volvo Penta Outdrive with duoprops. I'll probably be here a lot, seeing how I'm about to go through the boat from bow to stern. All new upholstery is in order, and I have water in my oil, so the heads are coming off quick. Gotta get this baby up and running within a couple months so I don't miss out on the summer fun.
Thank you outacontrol for this useful post!
Michaels1956 (03-24-2015)
  • Old 03-24-2015, 05:50 AM   #2
    Michaels1956's Avatar
    Michaels1956 is currently offline
    My Model: 2000 ZC
    My Engine: 5.7/V8 Alpha One
    Gallery Images: 4
    Send Michaels1956:
    Default Re: Hello from Arkansas!!
    I have a 92 2000Z that's green with Merc 5.7 Alpha One engine and merc. outdrive. I still have some work to do on mine but not that much left to do. :-) I'm from Alaska by the way, nice to see another 2000Z
    outacontrol likes this.
    Old 03-24-2015, 07:47 PM   #3
    Welcome to the MOC outacontrol, and congrats on your "new" 2000Z! Looks like she just needs a good cleaning and some TLC! A lot of us use the Meguiars Fiberglass Restoration Kit and have really positive results.
    You can PM me your hull id number and I can give you the info from the factory build sheets. This will at least give you an idea of what engine was originally installed.
    Old 03-26-2015, 11:40 PM   #4
    My Model: 2000 Z
    Send outacontrol:
    Thanks ShabahZ280!! The info from my HIN was very helpful. The interior is completely stripped out, ready for reupholstering, and the top end of engine is disassembled, ready for rebuild. Looking forward to putting this all back together and putting it in the water
    Old 04-04-2015, 12:49 AM   #5
    cswinings is currently offline
    My Model: z240
    My Engine: 7.4
    Send cswinings:
    When you took off you heads did it look like there was a blown gasket? Hope that its not something too serious like cracked block or something. I bought my 95 with a blown motor. After disassembly it was found to have spun a bearing and ate things up pretty good. Had to get an align bore along with the rest of the rebuild.
    Old 04-04-2015, 01:39 AM   #6
    My Model: 2000 Z
    Send outacontrol:
    Thanks for the concern cswinings. Actually, the worst case scenario occurred. I had a cracked block, cracked head, and a blown head gasket, not that the later mattered. Shopping now for an alternative, looking at some used 350's, also considering a freshly rebuild engine. I do not want to go through this again. But while the search is on, it's giving me time to get the boat cleaned up and the upholstery redone. Still looking forward to getting it in the water within a couple months.
    Old 04-04-2015, 02:17 AM   #7
    My Model: 2000 ZC
    Gallery Images: 4
    Send Michaels1956:
    Do you know why the engine block and heads cracked. Sorry to hear the bad news.
    Sent from my SGH-I317M using Tapatalk
    Old 04-04-2015, 02:26 AM   #8
    My Model: z240
    My Engine: 7.4
    Send cswinings:
    Normally it is from lack of or improper winterization.
    Old 04-04-2015, 12:09 PM   #9
    My Model: 2000 Z
    Send outacontrol:
    I really don't know the cause, bought the boat used. They said, "Overheated while on the lake, checked oil and discovered water in it." I've been told a lot that doesn't add up, so I've lost a lot of faith in the stories. So it's time to start from scratch and make sure every things done right on this rebuild.
    Old 04-05-2015, 03:28 AM   #10
    My Model: z240
    My Engine: 7.4
    Send cswinings:
    Sorry to hear that, but at least now you can rebuild it and make it the motor you want.
    « New Member | mr »
    1995 Z240 in Arkansas rayzorback Mariah Boats For Sale & Wanted 2 04-09-2012 08:52 PM
    275st in eastern Oklahoma and 180 Shabah in NW Arkansas knightriderz Mariah Boats For Sale & Wanted 3 02-20-2012 06:45 PM
    Newbi 2007 SX19 Owner in Arkansas dwymer64 Introductions 10 10-15-2010 07:43 PM
    Just aquired 220 Talari -- new member in NW Arkansas knightriderz Introductions 3 02-25-2008 11:41 AM
    There are 302 users
