need to get all of the brown stuff off
General Maintenance
Old 08-03-2008, 11:19 PM   #21
Originally Posted by my97camaro View Post
i just left my boat out for the 2 weeks i was not able to get back to the river. needless to say i have bird c___ and stuff all over the boat. i used the star brite from walmart for the hull and it is now spotless. what i need is something to clean the seats with (any ideas?) PLEASE HELP!!! IT LOOKS REALLY BAD.
Mr Clean Magic Erasers are great for the upholstery. Once done, treat it with a proper vinyl protectorant.
  • Old 03-10-2009, 09:36 PM   #22
    shoot001 is currently offline
    Send shoot001:
    Default Re: need to get all of the brown stuff off
    A product called Slimy Grimy is the best stuff I have used, by far. Buy it in the powder form and mix it up with hot water in a garden sprayer. I find that very little scrubbing is necessary.
    Old 05-11-2009, 07:50 PM   #23
    Billyclub is currently offline
    My Model: 1999 Shabah 182 Mercruiser 3.0L
    Send Billyclub:
    I use a product called Iron Out which is diluted with water and appliued with a sprayer. Let it set for awhile and then use some elbow grease or a power washer spray.
    Old 06-18-2009, 11:16 AM   #24
    Caspersa21's Avatar
    Caspersa21 is currently offline
    My Model: 246 Talari
    Send Caspersa21:
    I've heard muriatic acid works to clean hulls from other sources too. My question is, is it safe for the environment? Maybe it's best left to the professionals if not. If that's the case, I will have the dealership do it .
    Old 06-18-2009, 06:00 PM   #25
    Hi Caspersa21, the short answer - No.
    Muriatic Acid is Hydrochloric acid diluted in water, it's classified as a Hazardous material (see attached PDF file), it also react with metals like your trailer, outdrive and zincs.
    I suggest that unless you're comfortable and knowledgeable in handling these materials, look at having a professional do it.
    Old 06-19-2009, 08:17 PM   #26
    depman160's Avatar
    depman160 is currently offline
    My Model: 2000Z
    My Engine: 5.0L Merc Alpha 1
    Send depman160:
    Muratic acid is what my marina, and I suspect most marinas use.
    It works well, but the trick is to dealing with it is to take the boat and clean it ASAP after the acid bath to get the extra stuff off.
    Then, give it a coat of wax if you can. Then, in the spring, clean it and wax it again, and as the boat sits in the water, you can more easily just take a good scrub brush and just scrub it off.
    I try to do it weekly....takes about 10 minutes to just swim around the boat and wipe the crud off.
    We've done that for many years and it seems to do the trick.
    If only it could be summer all year long!
    Old 06-20-2009, 02:49 PM   #27
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    I believe most commercial hull cleaners are a solution of Oxalic acid. Not nearly as nasty as muriatic.
    My Mariah
    Old 06-21-2009, 01:42 PM   #28
    Z202's right. I use the "Star Brite" brand hull cleaners. They have 3 currently.
    "Hull Cleaner" - Oxalic Acid MSDS
    "Sea Safe Hull Cleaner" - Enviornmentally Friendly Oxalic Acid MSDS
    "EZ On EZ Off Bottom Cleaner" - Hydrochloric Acid MSDS
    I've had great luck with the Hull Cleaner for years, and this year I plan to try the Sea Safe Hull Cleaner. The nice thing about Star Brite brand is, you can get it pretty much anywhere, from West Marine to Wal Mart.
    Old 06-22-2009, 04:24 PM   #29
    Z 202's Avatar
    Send Z 202:
    Yeah, I used the Star-Brite hull cleaner last fall. It did a greate job with minimal effort. I still wore gloves and goggles, as it's still pretty corrosive stuff. Make sure you rinse the boat and trailer with liberal amounts of water afterwards.
    My Mariah
    Old 06-27-2009, 02:05 AM   #30
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    I've been wondering about leaving the boat in all season and what would happen.
    We paint the bottom of our sailboat with VC-17. When fall comes around and the boat is hauled, we just give the hull a good wash with a power-washer, perhaps hit some of the more stubborn spots lightly with a Scotch-Brite pad, and the crud is gone. No muss, no fuss, no acids. When spring comes around we give her hull a fresh coat of VC-17 and plop her in the water. It's all relatively painless. (Except for the $60/qt. VC-17 is up to, these days )
    Only thing is, anti-fouling bottom paint doesn't look as pretty as an unpainted, shiny white hull.
    One thing I do wonder about: Acid-wash, or whatever, or bottom-paint: How do you get under the skids on the trailer the boat's sitting on?
    Jim
    There are 250 users
