Temperature gauge
General Maintenance
Old 09-02-2014, 12:59 AM   #1
96MariahZ220 is currently offline
My Model: Z272 SHABAH
My Engine: 502 MAG MPI
Send 96MariahZ220:
Default Temperature gauge
First off I have a 96' Z220 with 5.7 mercruiser.... What is the normal running temp of the engine when it's "warmed up"? My temp gauge seems to not move up much. Just over 100... Do these have sensors that go bad? Ran it for several hours yesterday and it sounded great/ ran great. Any input is much appreciated. Thanks!
  • Old 09-02-2014, 01:39 AM   #2
    finleydj is currently offline
    My Model: 220 talari
    My Engine: 5.7
    Send finleydj:
    Default Re: Temperature gauge
    Mine is the same setup. I run about 180 degrees give or about 10.
    Old 09-02-2014, 01:40 AM   #3
    Send 96MariahZ220:
    Okay, that sounds about right, my temp reads way lower.
    Old 09-02-2014, 12:48 PM   #4
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Could be running without a thermostat.
    Old 09-03-2014, 12:45 AM   #5
    Send 96MariahZ220:
    Well you are exactly right. Pulled the thermostat housing off, not one there... Now I am concerned as to why there was not one in there... I went ahead and ordered a new one I'll put it in and hook it up to the muffs and she what happens.
    Old 09-03-2014, 10:26 AM   #6
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    It's good practice to pull the stat out when winterising. It may have just been overlooked in the spring rush to get on the water.
    Old 09-06-2014, 02:34 AM   #7
    Send 96MariahZ220:
    Okay, so I replaced my thermostat today with a 160 degree thermostat, surprisingly very easy to do. I let the boat run on the muffs it took a long time to warm up and finally settled in at the "1" on the 175 degree mark so just below 175 is where it idled at, maybe 165-170? I rev'd the RPMs up a little and it started to cool back down a little bit. Ran it for maybe a half hour or so... Does this sound about normal? Thanks
    Wanted: Temperature Gauge for Mariah SX18 Danish Mariah SX 18 Owner Mariah Parts For Sale & Wanted 3 10-31-2013 01:13 AM
    Temperature is jumping between 120 and 200 or so degrees Jacob Mercury MerCruiser 3 07-10-2011 03:31 AM
    Temperature sensor ?? lowerthanu Mercury MerCruiser 0 05-25-2010 04:21 AM
    Squirrelly Temperature Readings Captain Steve Original Mariah Talk 2 09-22-2009 12:01 AM
    No Engine Temperature SEMIJim Mercury MerCruiser 13 07-09-2009 07:04 AM
    There are 336 users
