Temperature is jumping between 120 and 200 or so degrees
Old 07-10-2011, 01:26 AM   #1
Jacob is currently offline
My Model: 180 Diablo
My Engine: 135 hp 4cy, Mercruise
Send Jacob:
Default Temperature is jumping between 120 and 200 or so degrees
While out on the river today, my power steering goes out and at the same time the temperature gauge starts jumping around between the above degrees. What is causing my power steering to go and what may be causing the temperature variance? Impeller? Are the two issues related or just coincidence? I bought this 2001 Mariah 180 Diablo, with a 135 horse Mercruiser 4 cylinder motor this spring. It is in impeccable conditon. I hope these are not major problems?
  • Old 07-10-2011, 01:41 AM   #2
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    Default Re: Temperature is jumping between 120 and 200 or so degrees
    Check your belts first! I bet its the same belt for the Power steering and the water pump.
    Zack
    1994 Z212 Shabah
    Thank you Zackattack for this useful post!
    Jacob (07-10-2011)
    Old 07-10-2011, 03:13 AM   #3
    Send Jacob:
    Thanks Zach, I looked closer, (too much excitement today) and did find that it was just a broken belt and it does run both the water pump and hydralic pump for the power steering. Issue fixed. Thanks again!!!
    Old 07-10-2011, 03:31 AM   #4
    Zackattack's Avatar
    Send Zackattack:
    Good job!
    Zack
    1994 Z212 Shabah
    Temperature sensor ?? lowerthanu Mercury MerCruiser 0 05-25-2010 04:21 AM
    Squirrelly Temperature Readings Captain Steve Original Mariah Talk 2 09-22-2009 12:01 AM
    No Engine Temperature SEMIJim Mercury MerCruiser 13 07-09-2009 07:04 AM
    Alarm Sounding, but pressure/temperature look fine? aggressivebuggy Sea Fox - Mariah Talk 5 06-29-2009 04:59 AM
    There are 315 users
