Bilge pump not running
General Maintenance
Old 07-03-2014, 01:15 PM   #1
jbharsch is currently offline
My Model: 182 Shabah
My Engine: Mercruiser 4.3L V6
Send jbharsch:
Default Bilge pump not running
I have a 1999 Shabah 182 and just dicovered the bilge pump is not running. It won't run from the console, even though the light on the switch comes on, or the float switch. Would this point to a bad pump? I have read through the other threads but didn't excatly see anything just like this.
  • Old 07-03-2014, 02:23 PM   #2
    Default Re: Bilge pump not running
    Check the fuse.
    Use a test light or voltmeter at the pump/float switch to see if you have power running to the pump.
    Check ground wires , they are a usual suspect in electrical issues due to corrosion.
    If you have power to switch , but not out , need new switch.
    Old 07-03-2014, 03:16 PM   #3
    Send jbharsch:
    I had already checked the fuse. The test light is next. Thanks for the advice.
    Old 07-04-2014, 01:31 PM   #4
    Iowa Mike is currently offline
    My Model: 1900Z
    My Engine: 3.4L Alpha I
    Send Iowa Mike:
    I have 1992 1900z and had the same problem it was the pump in my case. It was not real fun to get to, to change.
    Iowa Mike
    bilge pump dvoegele Original Mariah Talk 1 07-31-2012 01:08 AM
    Bilge pump alliedasset Boating 101 2 05-30-2012 02:36 AM
    Bilge Pump ROMFORD_NAVY Sea Fox - Mariah Talk 2 06-03-2011 01:22 PM
    Bilge pump andyc Sea Fox - Mariah Talk 7 07-14-2009 04:01 PM
    bilge pump John Miller Original Mariah Talk 7 05-18-2009 07:25 PM
    There are 302 users
