Removing decals
General Maintenance
Old 08-22-2013, 11:00 PM   #1
doaclnr is currently offline
My Model: Z302
My Engine: Volvo Penta 8.2 DP
Send doaclnr:
Default Removing decals
ok, I might get some gruff for this but I don't like the checkered flag on my 302. I peeled a couple of stickers off and noticed a little color difference from fade Im guessing. Anywho, maybe this has been brought up before but is there someway to remove the stickers and buff to match rest of boat? Maybe this is just a silly question... Anybody? lol
  • Old 08-23-2013, 01:09 AM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: Removing decals
    "Easiest way" to remove graphics is to use a hair dryer to heat the graphic a section at a time and then peel it off slowly. After getting off all the graphic, use some petroleum distillate (WD-40) to remove the remaining glue then buff and wax. It will have a witness mark where the graphic was located as the UV light will have not had the chance to fade the area under the graphic.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 08-23-2013, 02:46 PM   #3
    I did the same thing earlier this year. I used a heat gun, and acetone to remove the adhesive. It is a time-consuming process, but the look was worth it. See pics below (and ignore the scum line, it was there only for bottom painting purposes)
    I did have the same issue with the "ghosting" and after a few coats of polish & wax, it was much less noticeable. Now, 3/4 of the way thru the season, the ghosting is starting to come back a little more, and you can start to read the old name on the sides. I read on a few sites about wet sanding making a difference, but I'm very hesitant to do that just yet. I'll probably research it over the winter and see what options there are.
    Old 08-24-2013, 03:37 PM   #4
    I have done the wet sanding before. I was reluctant to at first but I figured the scuffs looked worse than sanded gelcoat. I started with 1500 and it did not take much. Ended with 2500 or 3000- I cant recall. After it was sanded I did some spot buffing with a cutting creme, polish and wax. (I dont think the cutting creme was needed). I cant even tell where the scuffs were before the process. They were in plain sight too.
    Thank you Motoxxx43 for this useful post!
    mikeyt (08-24-2013)
    Old 08-25-2013, 01:58 AM   #5
    Rynovw's Avatar
    Rynovw is currently offline
    My Engine: 1 man power & a PFD
    Send Rynovw:
    I wet sanded that whole boat when I got it. Started with 1500 then 2500 like moto did.
    But wasn't to worried about doing it. Cause I've done many cars an a few other boats in the pass. It's a lot of work just cause of the size of her height and length. Like 120 hrs. I went and got a small roll around scaffold...
    I'll go by the shop in the morning and get the name on the polishing compounds I used after wet sanding.
    There is a great web site for boat polishes http://www.performanceboatcandy.com/
    They also have great products just seen the result on buddies boat never used them personally.
    Call me if you have any question
    looking for a new ride. other then the 1 man powered PFD i currently have
    Removing swivel base papineau Introductions 3 07-02-2013 03:22 PM
    Removing Spark Plugs or not.... wplaine Mercury MerCruiser 0 02-22-2010 01:52 AM
    Removing cushions jetscat7 Original Mariah Talk 0 02-09-2010 10:33 PM
    Removing light scratches. Paul F Original Mariah Talk 6 09-30-2009 01:06 AM
    Removing Bottom Paint 300sflyer Original Mariah Talk 1 03-08-2009 11:35 PM
    There are 216 users
