New Mariah Owner with questions!
General Maintenance
Old 04-30-2013, 06:55 PM   #1
GravyTrain210 is currently offline
My Year: 1991
My Model: MX 19
My Engine: 4.3L MerCruiser
Gallery Images: 3
Send GravyTrain210:
Default New Mariah Owner with questions!
Hello to all,
I have just bought a 1991 Mariah MX 19. It has a 4.3L mercruiser V6. I cannot keep it running above 3000 RPM without it dying out. I have replaced the fuel filter, cleaned the carb and the main fuel in fitting on the carb. I have replaced spark plugs, wires, distributor cap and rotor. Cannot seem to put my finger on it at this time. I am begging for help. Its almost boating season!! lol. Thank you to anyone who has some insight for me.
  • Old 04-30-2013, 07:09 PM   #2
    Oregondunes's Avatar
    My Model: Z302 Bow Rider
    My Engine: 7.4 bravo3
    Gallery Images: 36
    Send Oregondunes:
    Default Re: New Mariah Owner with questions!
    when it dies, have you pulled a plug to see if they are wet or dry ?
    If wet, your loosing spark, if dry, your running out of fuel. Id look at the fuel line to the tank
    2000 Z302 Bow Rider
    Old 04-30-2013, 07:52 PM   #3
    Assuming you have done the fuel filter/carb/small filter at the carb inlet/distributor/fresh fuel etc.....then its time to change the fuel pump. It can't keep up with the demand of the engine.
    Old 04-30-2013, 08:44 PM   #4
    My Year: 1991
    My Model: MX 19
    Gallery Images: 3
    Send GravyTrain210:
    Thanks guys
    I did do the fuel filter, carb, carb inlet, plugs, wires, cap, and rotor. I was guessing my next best bet was the pump its self. Going to be doing a pressure check on that here soon. I will let ya'll know what I come up with. Thanks for the help. very much appreciated.
    Old 05-01-2013, 02:40 AM   #5
    Carroll is currently offline
    My Model: Z212
    My Engine: 350 mag
    Send Carroll:
    Pressure guage on the out line and vacuum guage on the suction side will tell the tale on the pump. If the vacuum is too high on the suction side you will get inadequate fuel volume when the engine demands it even if you have adequate pressure under idle or no load conditions. Mikeyt sounds like he is right on target and I think I'm getting too far ahead of the testing. The reason I mention it is because I ran into a fuel problem two weeks ago where there was a restriction in the suction line that only caused a problem under high engine loads.
    Old 05-01-2013, 04:03 PM   #6
    My Year: 1991
    My Model: MX 19
    Gallery Images: 3
    Send GravyTrain210:
    Default Fuel pump priming??
    I posted yesterday about my 4.3L Mercruiser not staying running at about 3000RPM. I took advice and replaced the fuel pump. Now...obviously it has to prime. Is there a certain way to prime it or do you just give it hell until it primes itself? We are watching the carb and we get a good spray for a minute and than nothing. I'm guessing it is just working the air out of the lines but am not sure. We are getting a better spray than yesterday with the old pump. Its just on and off at this point. Just wanted to see if anyone had suggestions or if I should just keep turning it over til it primes itself. Any advice would be appreciated. Thanks
    Old 05-01-2013, 05:30 PM   #7
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Default Re: Fuel pump priming??
    Have you checked the fuel strainer in the carb? (part 4 in the attachment)
    Thank you Andy b for this useful post!
    GravyTrain210 (05-01-2013)
    Old 05-01-2013, 05:46 PM   #8
    My Year: 1991
    My Model: MX 19
    Gallery Images: 3
    Send GravyTrain210:
    Thanks..That worked but......I just recently cleaned that a couple days ago. Any suggestions how to get that crud out of the tank with a full tank??
    Old 05-01-2013, 05:46 PM   #9
    What Andy B said! That was one of the things (small filter at carb inlet) i mentioned in my earlier post.
    Andy b likes this.
    Old 05-01-2013, 05:58 PM   #10
    My Year: 1991
    My Model: MX 19
    Gallery Images: 3
    Send GravyTrain210:
    You guys are very helpful!! It worked for now will have to keep checking that if I have problems.
    New Mariah owner with some questions stuartm77 Original Mariah Talk 2 07-11-2011 01:39 PM
    New owner, couple questions if you please midwest mariah Original Mariah Talk 4 07-14-2009 07:06 PM
    Parts, repairs and trailer questions from new mariah owner kgoo Original Mariah Talk 2 10-06-2008 03:25 PM
    new owner has questions geiffert Original Mariah Talk 3 05-28-2008 02:34 AM
    New owner with questions turfguy99 Original Mariah Talk 3 05-05-2008 01:30 AM
    There are 308 users
