Motor oil...
General Maintenance
Old 01-26-2013, 04:15 PM   #11
Oregondunes's Avatar
My Model: Z302 Bow Rider
My Engine: 7.4 bravo3
Gallery Images: 36
Send Oregondunes:
Does that include spark plugs and air filter or fuel filter?
2000 Z302 Bow Rider
  • Old 01-27-2013, 02:06 PM   #12
    MyOwnBoat is currently offline
    My Year: 2007
    My Model: FS 18
    My Engine: Mercruiser 135 hp
    Send MyOwnBoat:
    I don't think so.
    Old 01-27-2013, 02:18 PM   #13
    Default Re: Motor oil...
    That is a pretty big chunk of change for oil and a filter.
    Old 01-27-2013, 03:16 PM   #14
    Gallery Images: 36
    Send Oregondunes:
    you ever seen or replaced your sea pump impeller ?
    2000 Z302 Bow Rider
    Old 01-27-2013, 03:18 PM   #15
    My Year: 2007
    My Model: FS 18
    Send MyOwnBoat:
    Well, I've never had it serviced and it has 179 hours on it. I'm looking at oil, filters, lube, etc... Trying to determine if I should have a professional do it, or do it myself (?) I take care of my other vehicles myself
    Old 01-27-2013, 03:38 PM   #16
    My Year: 2007
    My Model: FS 18
    Send MyOwnBoat:
    No sir, but from looking at the manual, I'm beginning to understand their prices. And, considering it's taken me 26 years to finally own my own boat-I do not want to screw it up.
    Old 01-27-2013, 04:11 PM   #17
    I'm guessing their price includes changing the motor and outdrive oil, the oil filter and possibly a fuel separator if you have one installed but the biggest part of the price will be the labor cost to R&R the lower leg of the outdrive when changing the impeller.
    All any of these jobs takes is time. Do a online search/youtube search for videos showing how to change your Mercruiser outdrive impeller. IF you can use a set of socket wrenches, it's a fairly simple job that would be difficult to 'screw up' and the price you are quoting for this work is a little expensive. And use the same search for changing the outdrive oil. Again this is a straight forward job. Changing the oil in your Mercruiser engine is no different than changing the oil in a car with the exception that you should consider buying a hand powered or an electric oil vacuum (about $30) so that you can suck the oil out thru the dipstick tube into a large container. Warming the engine oil up first makes that job go easier & using an oil extractor makes much less of a mess.
    Old 01-27-2013, 04:56 PM   #18
    Gallery Images: 36
    Send Oregondunes:
    Still not exactly sure how they get the motor mounted sea pump out to replace the impeller. You'd have to be either be very small (to fit along side the motor in the engine compartment), or have very long arm to reach down that far and work blindly.
    2000 Z302 Bow Rider
    Old 01-27-2013, 05:03 PM   #19
    Gallery Images: 36
    Send Oregondunes:
    My services includes:
    Change engine oil and filter
    Replace fuel filter
    Replace spark plugs after fogging (every 2 years)
    Clean K&N air filter
    Replace drive fluid
    Clean sea skimmer screen
    Replace sea pump impeller (every 2 years)
    Flush and replace power steering fluid (every 3 years)
    Flush and replace power tilt pump/fluid (every 3 years)
    2000 Z302 Bow Rider
    Old 01-27-2013, 06:10 PM   #20
    I was thinking myboat meant just oils and filters. Didnt notice the part about the impeller.
    motor oil
    01 Z252 value with bad motor? super10lbz Original Mariah Talk 3 12-26-2012 04:23 AM
    can any one tell me what motor I have newbee1 Mercury MerCruiser 2 04-23-2012 10:59 PM
    Motor too low tonyo Original Mariah Talk 4 07-06-2011 03:06 PM
    Pulling the motor super10lbz Mercury MerCruiser 7 04-27-2011 07:21 PM
    Old Motor Dwight Prophet Introductions 1 08-02-2010 12:44 AM
    There are 307 users
