risers and manifolds
General Maintenance
Old 07-04-2010, 01:37 PM   #1
murphysocc's Avatar
murphysocc is currently offline
My Model: 1998 Shabah Z222
Send murphysocc:
Default risers and manifolds
I have a1997 Shabah with a 454 mecruiser. I cant find part #s anywhere because when i put in motor serial # it doesnt come up as valid. Any ideas
  • Old 07-13-2010, 11:42 AM   #2
    Default Re: risers and manifolds
    Usually part numbers are by the engine generation. They're usually identified by the first two letters in the engine serial number. For example, mine is L0, a Gen VI. Check this site, it might help you narrow down which generation you've got.
    Mercruiser Inboard/Outdrive
    Scroll down until you see the GM V8 427,502,540 and 572. The 7.4L's are listed there.
    Hope this helps.
    risers and manifols murphysocc Mercury MerCruiser 0 07-04-2010 01:31 PM
    Batwing manifolds bones774 Original Mariah Talk 9 06-22-2009 03:52 PM
    Newer Exhaust Manifolds cracking? aggressivebuggy Mercury MerCruiser 3 05-22-2009 07:07 PM
    Replacing Exhaust Manifolds? 300sflyer Mercury MerCruiser 6 01-22-2009 07:05 PM
    New Manifolds, Risers increased temp NyleRogers Mercury MerCruiser 2 07-26-2008 02:41 AM
    There are 237 users
