Rear trailer light clearance marker works but is very dim
General Maintenance
Old 07-09-2017, 04:53 AM   #1
1996 Mariah Z252 is currently offline
My Model: Z255 Shabah
Send 1996 Mariah Z252:
Default Rear trailer light clearance marker works but is very dim
It is in this location on my trailer. I just bought it brand new replacing the old one that was completely broken. I checked were the ground wire was mounted and I saw no issues there. (in perfect condition.) it works but it is very dim. I stupidity threw away the box to it so I would have a hard time returning it. Any suggestions if it is a wiring issue? Thanks.
  • Old 07-09-2017, 09:34 AM   #2
    My Model: Z202
    Send Firestone:
    Default Re: Rear trailer light clearance marker works but is very dim
    You have some resistance in the circuit somewhere. Did you check the voltage and resistance coming into the lights? I installed a new tail lights and had similar issues. I ended up running a new line. My guess is that the original one was shorting out along the way. I just abandoned it in the trailer so it is only a guess.
    TCJ95Z-235 likes this.
    John
    Thank you Firestone for this useful post!
    ROY850 (07-11-2017)
    Old 07-09-2017, 12:50 PM   #3
    TCJ95Z-235 is currently offline
    My Model: Z235 Davanti
    My Engine: 7.4L Bravo1 Corsa
    Send TCJ95Z-235:
    I'm with Firestone on this one. I'd run a new power & ground wire. To confirm the new light is functioning run an external 12V lead to the light. Also make sure the ground is good, remove the ground screw and clean the mounting area. A little unseen corosion will give you a problem. The original power lead could have been damaged when the original light was damaged. If like on my 95 Loadrite that center clearance light group is tapped into the left tail lamp for power. When you run the new wire twist & tape the new wire to the old at the center light and use the old wire to pull the new wire through the crossmember.
    Thank you TCJ95Z-235 for this useful post!
    Firestone (07-09-2017)
    Telescoping Rear Navigation Light joelmcf Original Mariah Talk 1 03-29-2017 08:59 PM
    Rear light bar sonnyduty Original Mariah Talk 2 08-31-2010 11:31 PM
    Trailer Clearance light repair. Paul F Original Mariah Talk 3 05-06-2010 02:26 AM
    rear light pole john elbro Sea Fox - Mariah Talk 3 07-30-2009 02:11 PM
    trailer light bajabob Introductions 6 01-02-2008 10:12 PM
    There are 294 users
