Rear light bar
Old 08-31-2010, 08:00 PM   #1
sonnyduty's Avatar
sonnyduty is currently offline
My Model: Shabah 202
My Engine: 5.7L Magnum V8
Send sonnyduty:
Default Rear light bar
Just wondering how the rear 360 light works? Does the switch for the bow turn on the rear also? I cant seem to get the rear to turn on? Front works fine. Thought maybe i was doing something wrong.
  • Old 08-31-2010, 11:02 PM   #2
    Default Re: Rear light bar
    Hi sonnyduty, you should have either a three position rotary or rocker switch for the Nav lights. Of course the center is lights off and one way will be the rear light only (at anchor) and the other will be the front and rear as well as the dash lights (underway).
    Of course start with the blub and if you have a Volt meter, check for 12 volts at the rear light socket, and if necessary, work your way back towards the switch. Typically, most electrical issues can be traced to loose or corroded contacts and/or connections, especially on the ground side.
    Good luck,
    Old 08-31-2010, 11:31 PM   #3
    sonnyduty's Avatar
    Send sonnyduty:
    Perfect thank you Willy.
    Keeping Rear Seat Up shabah96 Original Mariah Talk 4 09-04-2010 12:36 AM
    Water in rear 42hut Original Mariah Talk 1 07-21-2010 03:40 PM
    rear light pole john elbro Sea Fox - Mariah Talk 3 07-30-2009 02:11 PM
    Looking for rear part of bimini top urim Original Mariah Talk 1 05-27-2009 05:34 AM
    There are 369 users
