Docking light replacement
General Maintenance
Old 06-30-2017, 02:27 AM   #11
bisham is currently offline
Send bisham:
Default Re: Docking light replacement
I just changed the bulbs on my 275. I purchased two of these LED bulbs on eBay:
PAR36 Round LED Trapezoid Distance Beam Bulb Truck Tractor Aviation Work Light | eBay
The first one took me 2-hours to remove the old bulb. The second about 15-minutes. The new LEDs fit perfectly. I put new wires and connectors because the LEDs need to be correct on + and - connections.
Here is the process:
1. Use lots of Dawn soap. Did this in our kitchen sink. Work it around the edges of the bulb by pushing the rubber housing away from the old bulb until the edge has soap and a little water all the way around.
2. Cut off the silicone from around the wires on the back of the rubber mount.
3. Remove the wire connectors.
4. I used a 90 degree 4" long straight blade screwdriver (made for tight places) and worked it under the edge of the old bulb and pried up. Kept working around the bulb about every inch. Finally a small edge came out of the rubber groove. Kept up the process until the old bulb came out.
5. Clean it up.
6. Put new wires (black for ground and some other color for + on the new bulb.
7. Feed the new bulb and wires into the rubber casing.
8. Work the edges of the bulb into the groove. Takes a little work but they will pop in.
I did not take any photos of the process, but the LEDs are great docking lights.
tbrookens and Firestone like this.
The Following 2 Users Say Thank You to bisham For This Useful Post:
Firestone (06-30-2017), tbrookens (06-30-2017)
    Z255 Sabah Docking light replacement. 1996 Mariah Z252 General Maintenance 5 05-14-2017 10:11 PM
    docking light griffin General Maintenance 5 05-19-2014 05:53 PM
    Docking Light Mounting ColoradoDiablo Original Mariah Talk 3 03-22-2013 03:16 PM
    Docking light adjustment? ckgreenman General Maintenance 10 07-10-2009 10:09 PM
    Wanted: docking light bulb lcoen777 Mariah Parts For Sale & Wanted 14 07-09-2009 06:41 AM
    There are 375 users
