fuse size that protects hatch lifts?
General Maintenance
Old 04-27-2017, 10:44 PM   #1
lvlender's Avatar
lvlender is currently offline
My Model: Z 220
My Engine: 5.7 Merc
Send lvlender:
Default fuse size that protects hatch lifts?
Hello all,
would you know what is the correct size (in amps) glass fuse Mariah uses to protect the drivers-seat motor/engine-hatch lift circuit?
  • Old 04-27-2017, 10:52 PM   #2
    My Model: Z202
    Send Firestone:
    Default Re: fuse size that protects hatch lifts?
    As a silver member did you check the wiring diagrams in the member only section?
    John
    Old 04-28-2017, 12:09 AM   #3
    lvlender's Avatar
    My Model: Z 220
    My Engine: 5.7 Merc
    Send lvlender:
    yes, I already deciphered the wiring drawings. There is no mention of the fuse I have found.
    Old 04-28-2017, 12:59 AM   #4
    My Model: Z202
    Send Firestone:
    Mine is still in winter storage or I would have looked for you. My guess is that you only need a 5 or 10 amp.
    John
    Old 04-28-2017, 09:11 PM   #5
    chuse927 is currently offline
    My Model: 272z Barchetta
    My Engine: 7.4
    Send chuse927:
    My hatch lifts are gone and seats are there but don't seem to function. Are you saying they are on the same circuit? Maybe that's my problem.
    Sent from my SM-N920V using Tapatalk
    Old 04-28-2017, 09:22 PM   #6
    lvlender's Avatar
    My Model: Z 220
    My Engine: 5.7 Merc
    Send lvlender:
    Chuse927,
    yes the hatch actuators and the drivers seat is on the same circuit. Protected by a glass fuse under the drivers dash.
    Old 04-28-2017, 09:23 PM   #7
    My Engine: 7.4
    Send chuse927:
    Ok probably my issue then. I will check that. Would like the seats to work.
    Electric Hatch Lifts ShabahZ280 Original Mariah Talk 19 06-25-2021 07:03 PM
    Inline Fuse Size Money Pit Introductions 1 08-06-2014 04:21 PM
    Hatch lift size? seansmp8 Original Mariah Talk 0 03-11-2011 01:26 AM
    Boat lifts and weights jdecoudres Sea Fox - Mariah Talk 3 04-06-2010 01:36 PM
    Fuse Amp Size Douglas Alderman Boating 101 1 06-11-2008 06:04 AM
    Total Members: 18,990
    Total Threads: 13,324
    There are 260 users
