Murphy's Law
Chit Chat/Off-Topic
Old 10-13-2012, 10:11 PM   #1
husker_fan's Avatar
My Model: 192 Barchetta
My Engine: 4.3L Alpha I
Send husker_fan:
Default Murphy's Law
Here's a good one. I decided today was the day to winterize. Had all my filters, oil, antifreeze ready. Put the boat in the driveway, muffs on, water on and fired her up. Oh, wait, it wouldn't start. No power to the purple wire coming off the starter solenoid. Jumper wired it to make it run. Started warming it up, told my wife to lower the trim while I watched so it didn't hit the concrete. Oh, wait, the trim doesn't work now either. Several hours later I have a winterized boat without the oil changed (pump I bought new today to suck the oil out didn't pump anything but air). The trim and starter issues will have to wait till spring. Just thought I'd share my good fortune now that I'm not mad enough to take an axe to my boat(that ran perfect the last time I had it out). I am laughing now because this would normally be something that'd happen to me in the middle of the lake.
  • Old 10-14-2012, 12:30 AM   #2
    Default Re: Murphy's Law
    It suxs , but at least it waited til the end of your season like you said
    Larry
    Old 10-14-2012, 02:48 AM   #3
    Been there.
    Old 10-14-2012, 04:21 AM   #4
    m&mmariah is currently offline
    Status: Gold Contributor
    My Model: 180 Shabah
    My Engine: 4.3 Mercruiser 4v carb
    Send m&mmariah:
    I winterized mine today, too, as we just got back from two great days at Lake Havasu, AZ. For every bad experience, there's 100 good ones. Changed the engine oil, installed new oil filter & fuel/water separator filter, drained water from the block, the exhaust manifolds and the power steering cooler, fogged engine, and removed battery. Wife unit even vacuumed the carpet and cleaned the interior. I think I'm ready to put her away for a few months! Spring/summer will be her before we know it....Then it's time for a new impeller and fresh gear oil--and maybe spark plugs too, as they've been in for two seasons. Hoping for a wet winter and full lakes for next season!
    Old 10-15-2012, 05:14 AM   #5
    husker_fan's Avatar
    Send husker_fan:
    I've been thinking......these two things might be related. Odd both things lost power at the same time. Maybe something ignition switch related or a loss of power to a circuit? I may not be able to wait till spring to mess with it.
    Old 10-20-2012, 01:13 AM   #6
    husker_fan's Avatar
    Send husker_fan:
    Found the trim problem, bad connection. Starting issue I think is a bad starter solenoid. My r terminal has no power to run the fuel pump. Hopefully I'll find a solenoid here in town tomorrow.
    Old 10-23-2012, 08:23 PM   #7
    ConVICK_Pitbull's Avatar
    ConVICK_Pitbull is currently offline
    My Year: 2008
    My Model: SX19
    My Engine: 5.0L
    Send ConVICK_Pitbull:
    I can get you a ARCO starter. They are frankly the best ones to use in my opinion.
    What are your cards? I got a 6, a 5, a jack, a 4 and a 8. I win! What do you mean? I had a hand just like that and I didn't win. Because I win! This is bull****! All right, take it easy, man. Every time it's different cards. So what, relax, he's a kid. There should be same set of rules, no matter what age. Why does he always win? Because, I win!
    2008 Mariah SX19
    1985 Chaparral 187 XL
    Old 10-23-2012, 08:57 PM   #8
    husker_fan's Avatar
    Send husker_fan:
    I already ordered a new solenoid for 14 bucks shipped to my door, should be here by the 31st. No plans to replace the starter.
    There are 214 users
