Aerial wakeboard tower
Watersports
Old 05-26-2009, 03:42 PM   #11
dwmax's Avatar
dwmax is currently offline
My Model: Shabah 212 Limited
My Engine: 350 mag with alpha one
Gallery Images: 17
Send dwmax:
Default Re: Aerial wakeboard tower
Yes it was a little difficult only because I am very anal and there is alot of adjustments but the tower is very sturdy and am very happy with it. My only addvice to you is to take your time and measure before you tighten every thing up and put only one piece on at a time with two people. you will love the finished product.
Darrell
  • Old 06-09-2010, 03:27 AM   #12
    aland91's Avatar
    aland91 is currently offline
    My Model: Z202 Shebah
    My Engine: alpha 1
    Send aland91:
    That looks great, I have a 1999 Z202 Shebah. Do you know if your tower would work on my boat and would I be able to raise the bimini?
    Old 06-09-2010, 04:14 PM   #13
    dwmax's Avatar
    Gallery Images: 17
    Send dwmax:
    The tower should work on your boat. As for the bimini it to should fit underneath it. If you would like just measure how high your bimini sits above the floor and I will measure the height of my tower and tell you if it fits. If you still have questions on wether the tower will fit or not just call H2O Wharehouse and they can tell you if it will fit, they have a list of all the boats and can tell you what will work. Good luck and feel free to ask any questions
    Darrell
    Old 06-10-2010, 12:38 AM   #14
    aland91's Avatar
    My Engine: alpha 1
    Send aland91:
    That's allright I will get with them but I appreciate the offer. I have been researching them quite a bit and I really like the style of yours but I am concerned about there only being 1 bolt holding each arm down. I have seen others that have 2 bolts per bracket. I do want to get one but don't want to mess up the boat. Thanks for responding and again your boat looks great. I am also thinking about addind graphics. More research...Have a Great week and be safe out there.
    Old 06-20-2010, 07:26 PM   #15
    mastercraft95 is currently offline
    Send mastercraft95:
    Have you had any problems with your tower shaking in choppy water? I have the same tower and can not figure out how to stop it. I spoke with the tech at Aerial after I sent him some pictures and he thought everything looked correct????? I used plywood for a backing on mine similar in size to your plastic board backing plates. Thanks
    Old 06-21-2010, 11:16 PM   #16
    dwmax's Avatar
    Gallery Images: 17
    Send dwmax:
    Yes at first I had some shaking but that was before I put the backing on. When I put my backing on the inside I took a grinder and ground down the edges and center so the backing plate would mold to the inside of the boat. I also used two tubes of 5200 before securing the backing plate. What the 5200 does is fill any voids that I might not of gotten when grinding the backing plate. I lightly snug everything together to allow the 5200 to setup and then go back and really tighten everything all together and check all the other set screws. You have to check all the set screws constantly for the first few times that you use the tower,and by then the set screws will have completely seated into position and the towers should be completely secured. Good luck and let me know if this helps.
    Darrell
    Old 10-21-2010, 09:44 AM   #17
    josh3204 is currently offline
    My Model: 209SE Talari
    My Engine: 350 Mag
    Send josh3204:
    The tower looks awesome! I'm a little biased though. It's the same tower I put on our 97 Talari 209. Also thanks for the better backing ideas. Sad to see the season end!
    Old 03-11-2011, 05:13 AM   #18
    scubydo is currently offline
    My Model: 200
    Send scubydo:
    Originally Posted by dwmax View Post
    I just got my new aerial assault wakeboard tower from H2O Sports wharehouse. I installed it over the weekend and I have to tell you that it looks way better than I even hoped it would. I havent had a chance to test it out yet but will this holiday weekend coming up so I will keep you all posted I do however have some pictures of it after I put it on. Let me know what you think. I also added the pictures to the gallery
    Does the Aerial wakeboard tower fold down do you can get it in the garage? If so sign me up, I'll get one in a heartbeat.
    Old 03-11-2011, 11:06 AM   #19
    dwmax's Avatar
    Gallery Images: 17
    Send dwmax:
    The tower does fold down with just a little effort but I have never folded it down as my boat sits outside and under a cover so I havent a need to fold it down
    Darrell
    Aerial wakeboard towers wssb11 Watersports 19 07-23-2012 05:05 AM
    Wakeboard Tower boarder1010 Watersports 35 02-06-2011 03:39 PM
    Question about Wakeboard tower rjshelley Watersports 0 02-03-2009 02:33 AM
    Mariah Open Bow Wakeboard Boat with Tower - (Seattle) vicsem Mariah Boats For Sale & Wanted 0 05-12-2008 08:11 PM
    How to buy a Wakeboard Tower WetWilly Boating 101 0 03-25-2008 07:23 AM
    There are 233 users
