Aerial wakeboard towers
Watersports
Old 05-17-2010, 04:51 PM   #11
dbainbridge is currently offline
Send dbainbridge:
Default Re: Aerial wakeboard towers
Originally Posted by Jayhawk04 View Post
I've got an Aerial tower on my Diablo and I love it. I looked at a ton of different style towers before I decided on this one. I got it off Ebay for $630 or so. The install was pretty straight forward. I used extra backing that I made from 1"x4" PVC "wood" to help more evenly distribute the stress the tower puts on the glass. I found the PVC boards in the trim section of Home Depot. It took my brother and I a couple of hours to install and that was with me measuring things over and over to make sure I got it on right.
This winter I added some polished board racks and am in the process of adding some Kicker KMT6 tower speakers and a tower mounted anchor light.
The tower itself is light, being made of aluminum, but when boarding behind the boat there is a noticeable pull when the rider edges way out. It's nothing major, but it is noticeable.
The tower fold down below the windshield height, so I have no problem putting the boat in my garage.
Here are some pictures I took of the tower after I put it on last summer.
I just installed the Aerial wakeboard tower myself and it looks great! I was wondering if you had any pictures on how your speakers were installed, specifically how the wiring feeds from the tower tubes into the hull of the boat. Did the install of the speakers retrict the movement of the tower when folding down? Any tips would be great as I want to only drill the minimal amount of holes as needed!
  • Old 05-19-2010, 03:39 AM   #12
    mrzogs21 is currently offline
    My Model: Z209 Talari
    My Engine: 5.7L BravoI
    Send mrzogs21:
    I have a 96 talari and was looking into mounting a wake board tower and was just wondering if some one can help me a tell me if there is a way of popping out the inside panel, haveing to drills holes with a hole saw, or open for other suggestions.
    Old 08-29-2011, 12:57 PM   #13
    Mariahmaroo's Avatar
    Mariahmaroo is currently offline
    My Model: Z201 Talari
    My Engine: 5.7L Merc Cruiser
    Send Mariahmaroo:
    I just installed the Aerial Airborne Tower on my 1996 Z201 Talari. I started a new thread for it because I didn't see this one. It is awsome. No creaking or moaning of any kind from the tower. I used plywood to back up the tower with some epoxy called PC-11. This epoxy has a 1700 PSI tensile strength and is rated for use with marine applicaitons. Check out my post for some pics. It is tagged "Aerial Airborne Tower on 1996 Z201 Talari." Aerial Airborne Tower on 1996 Z201 Talari
    Old 08-30-2011, 03:10 PM   #14
    Send Mariahmaroo:
    I cut holes in the panel on my 96 talari for the back mounts. On the front left I went up through the speaker hole, and on the front right I went in from where the glove box should be on the bow. I chose to cut holes in the back because it was easy and completely concealed by the side bumper. Way less work than pulling the back seat, and then pulling all the screws to the side panels. Plus that fiberglass is structurally insignifcant. Just cut low because at the top there is a wood sticker that runs all the way back on the boat that you don't want to cut into because it is structural. Good luck.
    EDIT: ha ha I just realized the date in which you asked this question. You have probably since solved your dilema. Hope my reply can help somebody else.
    Old 03-07-2012, 07:28 PM   #15
    Medic1 is currently offline
    My Model: Shabah 202
    Send Medic1:
    I have been considering getting a tower for my 2001 Shabah 202, any particular brands to avoid? The local Marina sells monster towers but their prices seem higher than other brands are they really that much better? Thanks
    Old 03-10-2012, 10:38 PM   #16
    rayzorback's Avatar
    My Model: 210 LE
    My Engine: 454 Bravo 1
    Gallery Images: 10
    Send rayzorback:
    I like the looks of Monsters new MTK style. Don't have a clue about the mounting of it or the stress factor. I would surely put some exra support under the mounts to minimize cracking though.
    Old 06-07-2012, 01:50 AM   #17
    mike699's Avatar
    mike699 is currently offline
    My Model: 200 Talari
    My Engine: 5.0 L Mercruiser
    Send mike699:
    Well I don't have great pictures yet but here are some pictures of my Talari 200Z with an Aerial Airborne on it. I'm really happy with the look and function of it! Doesn't even make a creek or sound when my 250lb friends get behind her. The rubber mounts do allow for slight laterial movement when you pull on it from the side but it's not significant. I did have to pull out my rear speakers to get up under the sidewalls to mount it. I was then limited by the size of my speaker to size my plywood backing plates on the back mounts. I bought a wire harness from Aerial as well which is suited for lights and speakers. I will post pictures later of the wire routing install (most difficult part of the install). All in all I'm very happy with the value of the Aerial Airbourne but be careful when installing the tower as the chrome plating will scratch if you look at it wrong. I would recommend covering the entire tower in masking tape for the whole install.
    Happy Boating/Wakeboarding!!!
    Mike
    Oregondunes likes this.
    Old 06-07-2012, 04:59 PM   #18
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    That does look good. Congrats. The photo with the old barn in the background is pretty cool.
    Old 06-29-2012, 05:26 PM   #19
    Bmowild is currently offline
    My Model: Talari 210
    My Engine: 4.3 Alpha
    Send Bmowild:
    Just purchased an Aerial Assualt for my 94' Talahri 210. I will let you guys know how it goes during install. I will post some pics before, during and after. If anyone has any tips let me know..
    Old 07-23-2012, 05:05 AM   #20
    Send Mariahmaroo:
    Get ready for your arms to get scratched up...
    Also when I installed mine I used a piece of 1/4" plywood backing and a water proof epoxy with a 1700 psi tensile strength called PC-11. I recommend using it, or something like it for structural support. The boats fiberglass wasn't designed for a tower so you could end up cracking your gelcoat when you put pressure on it from pulling a skier. Mine hasn't cracked at all with the plywood and epoxy backing. Hope this helps. Ps drill your holes in reverse.
    Sent from my Evo 3D using Tapatalk 2
    1996 Z201 Talari 5.7L
    Wakeboard Tower boarder1010 Watersports 35 02-06-2011 03:39 PM
    Wake Board Towers Double D Original Mariah Talk 2 07-08-2008 04:30 AM
    Mariah Open Bow Wakeboard Boat with Tower - (Seattle) vicsem Mariah Boats For Sale & Wanted 0 05-12-2008 08:11 PM
    Samson Announced New Wakeboard Towers bdbyrnes Boating 101 0 04-02-2008 05:04 AM
    How to buy a Wakeboard Tower WetWilly Boating 101 0 03-25-2008 07:23 AM
    There are 285 users
