-   Volvo Penta (http://www.mariahownersclub.com/forum/volvo-penta/)
-   -   What to ask, 4.3l Penta (http://www.mariahownersclub.com/forum/volvo-penta/8261-what-ask-4-3l-penta.html)
gsaps 06-12-2013 04:16 AM
Hello to all on the forum and thanks for any help.
I'm currently looking to get a 2000 Mariah with a 4.3l Volvo penta outdrive with about 400hours, the seller says it has a service history but knowing exactly nothing about boats (never mind engines), I'd appreciate some advice.
Aside from oil changes, what should have been changed in an engine of this age, I'd like to ask the questions but I'd like them to be good questions so would be very appreciative of any help.
Grant
mikeyt 06-12-2013 01:04 PM
Re: What to ask, 4.3l Penta
I'm not very familiar with Volvo Pentas but there are quite a few here who have them and swear by them....and sometimes at them. I'll give the standard response to anyone looking to buy a used boat. Knowledge is key to being happy with what you are buying so check the following:
Get copies of (or at least look thru) the vendor's service records and ensure that it was properly winterized each fall. If you see a 'rebuilt block or 4.3 or whatever invoice dated in the spring, then it likely wasn't done or wasn't done right. If you are going to buy the boat, get copies of his service records.
Pull the oil dipstick and see if the oil looks fresh. Check the level of the out-drive oil in the reservoir. If you dont know where it is, ask the vendor to show you.
Have a look at the general cleanliness of the boat and the motor/bilge area. That will give you an idea if the owner had some 'pride of ownership' and kept her maintained.
Take someone with you to view the boat who is knowledgeable (or at least pretends to be) about boats and get her on the water for a performance test. If your 'helpful' person is good, buy 'em lunch!
Make sure all of the electrics (switches/lights/power trim & tilt) work.
Make sure all of the interior trim pieces are present and/or in good condition. Sourcing trim pieces and particularly glass can be difficult.
Make sure all of the canvas covers are included & in good condition. Replacing them can be pricey.
Make sure the vendor can prove ownership of the boat. You dont wanna get stuck buying something that belongs to someone else....
Best of luck and keep us posted on how you make out!
gsaps 06-12-2013 01:12 PM
thanks Mikeyt, a lot to consider, i might resort to getting a shop to check it over, it's on sale by a private seller.
I've often wondered about winterizing boats, I'm assuming this is necessary only ni certain climates, I'm in new south wales in oz, I'm assuming winterizing isn't as necessary
mikeyt 06-12-2013 01:15 PM
You are a 'ways off' aren't you? :yes_grin: If there is any chance of freezing temps then winterizing is a necessity if you dont have a heated shop to store the boat in. We've got a few Aussies on board here. Check out our Member Map when you have a few minutes.
